F.I.T Valve or Map Sensor?!?!?!?!
Old Nov 25, 2006 | 07:17 AM
Nickg116's Avatar
Default F.I.T Valve or Map Sensor?!?!?!?!
Got a eg w/ a b18b1. When i start the motor it idles rough for 5-6 sec then go to about 2.5-3k for another 5-6 sec then downs UP<DOWN>UP>Down. Took the fit valve out and clean it and tighten it all the way up still does it. So i disconnected the map sensor while it was doing it and it idle's fine. Car has no c.e.l and run awesome just has a werid start up. Once warmed up it idles fine.
Old Nov 25, 2006 | 07:24 AM
Nickg116's Avatar
Default Re: F.I.T Valve or Map Sensor?!?!?!?! (Nickg116)
maybe a vacuum leak?
Old Nov 25, 2006 | 09:07 AM
civicstar's Avatar
could be that but mostlikely IACV
Old Nov 25, 2006 | 10:27 AM
Nickg116's Avatar
Default Re: F.I.T Valve or Map Sensor?!?!?!?! (civicstar)
the fit valv eis inside the iacv right?
Old Nov 25, 2006 | 01:25 PM
Nickg116's Avatar
Nazraki
Feb 17, 2018 01:22 PM
khkchan
Sep 13, 2012 11:21 AM
aznfreakyguy
Jul 3, 2011 12:24 AM
eghatchproject
Dec 24, 2003 05:16 PM
GQ 05YellowEVO8
Jul 12, 2001 09:23 AM
