Ignition Timming HELP ??
92 Prelude DOHC 2.3 Non V-Tech
What is the best way to check the timming
Had the timmg belt break,, bent valves,, now it's back togather.. all fixed
HELP THANKS.
HELP THANKS.
Ignition timing you use a timing gun on the flywheel through the special hole in the tranny. You also have to jump the ECU so it doesn't correct for your changes (if you need to change it).
Cam/crank timing use the cam gears plus either the flywheel marks or the mark on the crank pulley.
