HELP FROM SOMEONE WHO HAS DONE IT PLZ.....D16Y7 IN EJ1
If some one can come look at it and help physically..I got a lil incentive.I got a y8 head,89k no grinds y7 dx tranny,a sony xplod 10'...take ya pick...I need my Teal Bandit back running
Simply.....Will this work
or
D16Y7 Longblock
Z6 tranny
Z6 Intake Mani and Header
Obd1 Injectors
Obd1 Alternator
Obd2 Y7 Dizzy with obd1 Plugs-
P28-I'll throw codes till I get my P06
It's My 1st Swap
Im never doin a swap again without correct tools
And a lift or at least 2 good jacks again....Im Learning
Thatll work, i just put one in the other day although i used a type R harness (was on the car already) so i didnt have to convert anything, put the z6 intake manifold on, hooked up everything and it went.
If your converting to obd1 i would get an obd1 dist. as well. But its up to you, very easy swap.
Ight today I wired up the Y7[obd2] dizzy with tha obd1 plugs.
I hear the fuel pump
I have spark
My back-up Ecu fuse was blown so i replaced it and tried to start it again...i got nothing but cranking
When i used the obd1 dizzy i heard more of a chance of starting and it was sputtering as if tha car was on because tha battery light was off as a kept the key fully on
I have spark
Stock Ex harness and ya im sure I got spark
Any thoughts or suggestions plz let me kno
OK mayb tha origin of the motor would help....
89K
96' Ek hatch
It was running perfect up until the day it when in to tha garage,then tha
motor was pulled out
few months ago and was sitting in the garage
89K
96' Ek hatch
After turn tha key and listening....I think i found tha problem! The bulb for tha CEL light has been removed or blown.
...because i hear it go off after i hear tha pump and tha srs light goes off
Thatsa rite because it never went off when starting even when my Mini Me from tha 1st day i bought tha car i never saw a cel....I over looked it
Wat a noob mistake
...because i hear it go off after i hear tha pump and tha srs light goes offThatsa rite because it never went off when starting even when my Mini Me from tha 1st day i bought tha car i never saw a cel....I over looked it
Wat a noob mistake
djaxis
Feb 22, 2010 06:48 AM
dunkd
14
Jan 31, 2006 04:36 AM
hatchback_al
Sep 27, 2004 11:31 AM
