Honda S2000 Honda S2000
04 tranny 2nd gear grind and motor mount question
Old Nov 24, 2006 | 08:04 PM
Crafte's Avatar
Default 04 tranny 2nd gear grind and motor mount question
Hi All,
I just purchased an 04 black s2000 with 17K miles on it.
When shifting to 2nd gear from 1st, is it normal for it to feel notchy and I an almost hear a grinding noise? I'm guessing its not normal, but is there any ideas whats causing it? Also it only happens in 2nd gear and usually at lower rpms ( like under 3 ).
Ocassionally it'll shift smoothly into 2nd. Downshifting into 2nd is always ok, smooth as butter.
Also when I turn off the engine, is it normal for the car to rattle/shake hard? I thought it may be the motor mount, but it only has 17K miles on it.
I had an ITR before and never notice any quirks like I having with the s2000. Thanks for the info and I'm loving my new s2000. Should of bought it a long time ago!!
Old Nov 25, 2006 | 10:38 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: 04 tranny 2nd gear grind and motor mount question (Crafte)
1-2 shift may be notchy at first; synthetic tranny fluid solved my problem. Try Honda's new MTF, Redline, Royal Purple, or AMSOIL.
eswint2010
Honda S2000
25
Feb 7, 2011 09:26 AM
IntegraLs94Cam
Honda S2000
May 5, 2007 09:01 AM
TylerC
Jan 6, 2006 09:17 AM
TylerC
Jan 5, 2006 10:21 AM
DC5 Demon
Oct 6, 2005 11:48 AM
