difference in oil pumps b series
i have heard to many debates over this.what is the real difference between a b18a/b18b pump,b16 pump,b18c1 pump and the type r pump.i have heard high volume high oil pressure and such.whatis the actual flow numbers.how many extra pounds of pressure.homany more quarts per hour does it push.i tried a search and found nothing.interesting note though.the type r pump is stamped p72>wtf?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">I cant tell you numbers, but I can tell you that ALL obd2 b series oil pumps are the same
meaning, "itr pumps" arent anything special</TD></TR></TABLE>
Just get an obd2 oil pump
dont know but i iknow mine is gsrp72 my friend has a type r it says p73 96 and newer have crank position sensor so they look a little different the typer r pump flows a tat bit then gsr ....from what someone that went through this told me but said it was so small different in flow that he picked up a p72 b/c it was in stock at acura. id say use gsr..buy a new one 4 extra insurance....
Circuit Star-29
Apr 25, 2005 09:41 PM
