difference in oil pumps b series
Old 11-24-2006, 04:45 PM
SCIVIC94's Avatar
Default difference in oil pumps b series
i have heard to many debates over this.what is the real difference between a b18a/b18b pump,b16 pump,b18c1 pump and the type r pump.i have heard high volume high oil pressure and such.whatis the actual flow numbers.how many extra pounds of pressure.homany more quarts per hour does it push.i tried a search and found nothing.interesting note though.the type r pump is stamped p72>wtf?
Old 11-24-2006, 04:52 PM
pdiggitydogg's Avatar
I cant tell you numbers, but I can tell you that ALL obd2 b series oil pumps are the same
meaning, "itr pumps" arent anything special
Old 11-24-2006, 06:07 PM
SCIVIC94's Avatar
Default Re: (pdiggitydogg)
cool.anyone know if obd 1 and 2 are the same?any other opinions.
Old 11-24-2006, 06:20 PM
vtec obd1 and 2 are the same (to my knowledge)
obd1 ls pumps flow less
Old 11-24-2006, 06:29 PM
SCIVIC94's Avatar
ok that was my big thing.i have an obd1 ls.i was looking at typer pumps but cant justify paying typer money if it is not worth it.thanks
Old 11-24-2006, 06:30 PM
SCIVIC94's Avatar
Default Re: (SCIVIC94)
is obd2 ls different then the vtec?
Old 11-24-2006, 08:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">I cant tell you numbers, but I can tell you that ALL obd2 b series oil pumps are the same
meaning, "itr pumps" arent anything special</TD></TR></TABLE>
Just get an obd2 oil pump
Old 11-24-2006, 08:12 PM
turbod da's Avatar
dont know but i iknow mine is gsrp72 my friend has a type r it says p73 96 and newer have crank position sensor so they look a little different the typer r pump flows a tat bit then gsr ....from what someone that went through this told me but said it was so small different in flow that he picked up a p72 b/c it was in stock at acura. id say use gsr..buy a new one 4 extra insurance....
PabloM
09-22-2013 06:52 PM
CRXherbie91
03-24-2009 09:46 PM
Boostin_GSR
03-13-2007 02:17 PM
ekVtecPower
06-11-2006 08:55 AM
Circuit Star-29
04-25-2005 09:41 PM
Quick Reply: difference in oil pumps b series
