00 civic si y8 tranny weirdness
Old Nov 24, 2006 | 04:22 PM
coreyhayman's Avatar
Default 00 civic si y8 tranny weirdness
i can switch gears without using my clutch, if i pull on the shifter to the next gear give it gas let the rpms get to 3,000rpm then soon as it starts to drop it will slip in, i can do it every gear except 3rd cuzz i got a 3rd gear grind. This normal it never used to do it?
Old Nov 24, 2006 | 04:49 PM
Nameless Warrior's Avatar
Default Re: 00 civic si y8 tranny weirdness (coreyhayman)
I would also like to know. Also, i can pull my gear OUT at low RPM without clutching.
Old Nov 24, 2006 | 04:51 PM
Carbonciv's Avatar
Default Re: 00 civic si y8 tranny weirdness (Nameless Warrior)
lol
Old Nov 24, 2006 | 05:37 PM
k20EP3's Avatar
Default Re: 00 civic si y8 tranny weirdness (Carbonciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior &raquo;</TD></TR><TR><TD CLASS="quote">I would also like to know. Also, i can pull my gear OUT at low RPM without clutching.</TD></TR></TABLE>
Dude you can pull any stick out of gear without the cluch, its a safety thing. And its called rpm matching the gears, you can do that with most cars if you do it right.
Old Nov 24, 2006 | 05:59 PM
jrs2ksi's Avatar
Default Re: 00 civic si y8 tranny weirdness (k20EP3)
they call it speed shifting. At the right rpm u can shift through any gear. It will pop out too w/o the clutch like he said.
Old Nov 24, 2006 | 06:28 PM
cambopheonix56's Avatar
Default Re: 00 civic si y8 tranny weirdness (jrs2ksi)
I think the real question is why do you have a y8 tranny is your SI?
Old Nov 24, 2006 | 06:37 PM
sicones's Avatar
Default Re: 00 civic si y8 tranny weirdness (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">I think the real question is why do you have a y8 tranny is your SI?</TD></TR></TABLE>
Canadian Si = US EX
Old Nov 24, 2006 | 06:55 PM
Default Re: 00 civic si y8 tranny weirdness (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">Canadian Si = US EX</TD></TR></TABLE>
Oh hahah didn't realize he was from canada
Old Nov 24, 2006 | 07:49 PM
fishnfst's Avatar
Perfectly normal.. Can be done with all stick shift cars.. I have a class A license and the only gear we use the clutch for is 1st or 2nd depending on how big a load you are carrying.. It does wear on your synchros though...
Old Nov 24, 2006 | 09:42 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote"> It does wear on your synchros though...</TD></TR></TABLE>
X A MILLION
Modified by ek forever guy at 8:53 PM 11/29/2006
Ammosmoke
17
Oct 23, 2010 04:54 PM
crazyness462
Jan 20, 2008 01:44 PM
JDM00SI
Feb 1, 2005 05:09 AM
JDMflavor_EJ
Jul 12, 2004 09:07 PM
