which wire is positive?
Old Nov 24, 2006 | 08:17 AM
aznryd3r's Avatar
Default which wire is positive?
there is a black wire...red with white stripe wite and a red with blue stripe wire...which one is positiive?
Old Nov 24, 2006 | 08:27 AM
Luserkid's Avatar
Default Re: which wire is positive? (aznryd3r)
None of those sound like a positive type wire. Take out a multimeter and check which gets batt. voltage.
Old Nov 24, 2006 | 08:35 AM
aznryd3r's Avatar
Default Re: which wire is positive? (Luserkid)
the voltage meter lit up everytime i tested each wire
Old Nov 24, 2006 | 08:37 AM
Luserkid's Avatar
Well what voltage did it read? If you see the same volts as your batt then thats your positive wire.
Old Nov 24, 2006 | 10:05 AM
sirsol66's Avatar
What is this wiring for? If you tell us that we might be able to help better...
wwolf771177
Feb 4, 2014 02:25 PM
hotimportcrx
Nov 1, 2005 07:19 AM
Zero2Sixty
May 22, 2003 10:38 PM
T25 civic
Oct 6, 2002 02:11 PM
