tranny problem!!!
Old Nov 24, 2006 | 06:01 AM
spanish-ek'hatch's Avatar
Default tranny problem!!!
ok heres the story i did a ls swap to my 94 hatch, i had a complet ls swap that came off my boys teg, the tranny work perfectly fine no grinds. i put it in the eg and started it , i put it in first and the car didnt move at all, second the same thing, i put it in third and the car pulled off hard like the car was in first. the 1st gear was 3rd gear, 2nd gear was 4th gear and 3 gear 4th. the first thing that i tought it could was the shift linkage so i changed them both and it was still doing the same thing, HELP
Old Nov 24, 2006 | 07:21 AM
Ls_eg6's Avatar
Default Re: tranny problem!!! (spanish-ek'hatch)
Did you use a clutch alignment tool when putting in the clutch, and make sure it's facing the right way?
Old Nov 24, 2006 | 03:25 PM
Bense's Avatar
how's your motor mounts?
Old Nov 24, 2006 | 04:44 PM
Default Re: (Bense)
the motor mount are good
Old Nov 25, 2006 | 12:08 PM
frostyrb's Avatar
Default Re: (spanish-ek'hatch)
If the clutch was off alignment the trans would never be able to bolt up. I don't know about the gear problem, but do you have the correct axles & are they installed all the way?
Old Nov 25, 2006 | 04:57 PM
Default Re: (frostyrb)
yes i have the correct axles they came with the swap, i also dubbled checked everything...
BULL3TPR00F
Feb 14, 2012 10:00 PM
slayersluck
Jan 13, 2007 11:36 PM
.paul
Jan 12, 2007 12:35 PM
vtec69
Mar 28, 2003 09:15 PM
TurboIntegra
Sep 8, 2001 09:48 AM
