Compression test results
Old Nov 23, 2006 | 08:50 PM
quick87crxsi's Avatar
Default Compression test results
Did a compression test on my D15b7 because it is smoking white smoke slightly. Here are the results:
cyl 1- 153
cyl 2- 155
cyl 3- 160
cyl 4- 160
Just wondering if these numbers are good, bad, or what. any feedback would be appreciated.
Old Nov 24, 2006 | 03:51 AM
Default Re: Compression test results (quick87crxsi)
anyone?
Old Nov 24, 2006 | 05:04 AM
s10cky's Avatar
They are all within 10 points of eachother. looks great.
white smoke could be coolant in the combustion chamber, or you may need a valve job.
Old Nov 24, 2006 | 06:10 AM
yea thats what i figured. I've got a v-tec d16 head that im gonna do the mini me head swap with. Should take care of the problem.
Old Nov 24, 2006 | 06:59 AM
daddycivic's Avatar
Bad head gasket can cause smoking. White smoke is from coolent get in the combustin chamber. If you do the head swop, get the head resurfis and get new head gasket.
Old Nov 24, 2006 | 08:16 AM
s10cky's Avatar
oh cool, get the head pressure checked, milled a little bit if needed and checked for straightness, a new head gasket and If that was your problem then you are good too go. I good days work.
Old Nov 26, 2006 | 11:45 AM
Fat Chick Magnet's Avatar
Default Re: (s10cky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky &raquo;</TD></TR><TR><TD CLASS="quote">They are all within 10 points of eachother. looks great.
white smoke could be coolant in the combustion chamber, or you may need a valve job.</TD></TR></TABLE>
so valve job can stop the white smoke?
Old Nov 26, 2006 | 05:42 PM
s10cky's Avatar
thanks, didnt think about that. It would help with black smoke.
Red-Rag-B18
Aug 23, 2010 05:33 PM
honda luv
Jun 30, 2009 12:05 PM
zcmotor
May 29, 2008 07:04 PM
kidd3121
Feb 18, 2008 01:20 PM
95strfytr
Apr 20, 2005 11:10 AM
