head gasket? smoking engine
Re: head gasket? smoking engine (95strfytr)
smoking at WOT doesn't necessarily mean a HG issue. If you are experiencing no coolant loss, but some oil loss it could also be the rings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95strfytr »</TD></TR><TR><TD CLASS="quote">i did the compression test and the cylinders were all around 170.</TD></TR></TABLE>
White smoke is what you're looking for when you're dealing with the headgasket.
The only way to be sure though, is to do a leakdown test.
Re: head gasket? smoking engine (EVIL Hx Coupe)
I pulled the pcv valve and I smell fuel. It also has lost a lot of power. The engine has 80000 on it. The valves are out of adjustment as well, but not too bad.
I'm about to put a y8 head on it. But i want ot make sure that it's gasket before i proceed. How do you do a leakdown test?
EARLdaSQUIRREL
10
08-08-2003 02:43 PM
