AN line how to the earls end is there a how to or can someone answer this
Old Nov 23, 2006 | 05:10 PM
JDMCRX's Avatar
Default AN line how to the earls end is there a how to or can someone answer this
Im pretty sure im doing it right.
put the hose in tell the bottom of the threads then put the center in and screw it down??
Old Nov 23, 2006 | 05:12 PM
JDMCRX's Avatar
Default Re: AN line how to the earls end is there a how to or can someone answer this (JDMCRX)
Old Nov 23, 2006 | 05:50 PM
snoot_works's Avatar
Pretty much, yep. The hose will bottom on the step inside the socket... Use some lube on the nipple and the threads, make sure you get it started square (not cross threaded) and tighten it up until there's 1/16" (or less) gap between the socket and the nipple.
It's a good idea to pressure test your hose assemblies - at the very least, ones that are destined for critical fluids.
Old Nov 23, 2006 | 05:55 PM
HamiltonRex's Avatar
Default Re: AN line how to the earls end is there a how to or can someone answer this (snoot_works)
yes what i do (instructions from stan) is put the first piece in the vice (plastic vice) screw the hose in using pressure foward, then after put the other piece in the vice, and thread the first piece (with hose threaded in) into the 2nd piece applying pressure.
Should work.. Sorry i dont know the names for the pieces.
Old Nov 23, 2006 | 06:18 PM
JDMCRX's Avatar
Default Re: AN line how to the earls end is there a how to or can someone answer this (HamiltonRex)
Thats cool did this so i was doing it right thanks guys
h22sedan
Welding / Fabrication
Dec 26, 2006 11:44 AM
Dunc
Jun 18, 2006 09:30 PM
SJP0tato
Mar 14, 2003 08:34 PM
comptechgsr2000
Feb 13, 2003 04:17 PM
Sonny
Feb 9, 2003 09:40 PM
