Car rolls forward while parked in gear.
Old Nov 23, 2006 | 03:13 PM
mkazm83's Avatar
Default Car rolls forward while parked in gear.
Today I parked my car in my driveway which is at a slight incline. I left the car in second, turned it off and proceeded to grab my stuff out and the thing started to slowly creep down. It rolled slowly forward, then it felt as if it rolled one crank rotation then stopped. Mechanically the car is sound, with no knows problems. I tried it in second and reverse with the same result. This is the first time this has happened to me, should I be worried?
Old Nov 23, 2006 | 03:30 PM
GraphiteMW's Avatar
E-Brake?
preludedriva's Avatar
should be left in 1st gear anything else and you might roll
Old Nov 23, 2006 | 03:35 PM
mkazm83's Avatar
Default Re: (GraphiteMW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteMW &raquo;</TD></TR><TR><TD CLASS="quote">E-Brake?</TD></TR></TABLE>
It wasn't in use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva &raquo;</TD></TR><TR><TD CLASS="quote">should be left in 1st gear anything else and you might roll</TD></TR></TABLE>
Didn't know that, I always thought second would have been sufficient.
Old Nov 23, 2006 | 03:42 PM
GraphiteMW's Avatar
I always leave my car parked in neutral but my drive way is pretty much level.
Old Nov 23, 2006 | 03:44 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteMW &raquo;</TD></TR><TR><TD CLASS="quote">I always leave my car parked in neutral but my drive way is pretty much level.</TD></TR></TABLE>
As do I, however, this was after the brakes got really hot and I'm trying to avoid pad deposits on the rotors.
Old Nov 23, 2006 | 04:05 PM
Default Re: (mkazm83)
k dono how to explain but in lamens terms 2nd gear isnt as "strong" as first try leaving it in 3rd on a hill see what happens you will roll so 2nd would be the same there for just leave it in 1st :D and ebrake always
Old Nov 23, 2006 | 05:49 PM
Quick99Si's Avatar
Default Re: (preludedriva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva &raquo;</TD></TR><TR><TD CLASS="quote">k dono how to explain but in lamens terms 2nd gear isnt as "strong" as first try leaving it in 3rd on a hill see what happens you will roll so 2nd would be the same there for just leave it in 1st :D and ebrake always </TD></TR></TABLE>
It's probably related to the gear ratios (reverse torque multiplier?). 1st is usually shorter than reverse in most cars/transmissions, Preludes included.
What's amazing to me is that the starter is strong enough to pull the car in 3rd + gear with the ebrake engaged all the way.
Adi
Old Nov 23, 2006 | 06:51 PM
Sakanora's Avatar
use your e brake if it's a slope
any parked car will roll slightly until the gears lock if you don't use the e-brake, this includes automatic cars when it's in P.
Old Nov 23, 2006 | 09:22 PM
ninja 6's Avatar
Default Re: (Sakanora)
People use second gear to bump start sometimes.
Old Nov 23, 2006 | 10:15 PM
ethereal2pt2's Avatar
Default Re: (ucd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ucd &raquo;</TD></TR><TR><TD CLASS="quote">People use second gear to bump start sometimes.</TD></TR></TABLE>
bump start?
i always keep mine in first. it doesn't roll w/o the ebrake. i live on a good slope. ebrake always of course.
Old Nov 23, 2006 | 11:05 PM
darkspector2.0's Avatar
bump start
push start
you can roll your car with your car ignition on, clutch in and in 2nd or whatever gear.... get a good roll and dump the clutch. it will start your car
Old Nov 23, 2006 | 11:12 PM
Default Re: (darkspector2.0)
oh thanks. would that not hurt the clutch/engine/whatever??
Old Nov 23, 2006 | 11:16 PM
well, if your battery is relatively dead and don't have enough cranking amps and are without jumper cables.... hah... it helps. It can't be much worse than these foo's doing burn outs
Old Nov 23, 2006 | 11:25 PM
i don't get ppl who do burnouts.. i hear ppl who drag say they do it to heat up the tires but you can just drive around for a few mins to heat them up. a waste of good tires. well nothings funnier than watching ppl tryna burnout w/ open diff.
Old Nov 24, 2006 | 12:50 AM
Default Re: (_BB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BB6 &raquo;</TD></TR><TR><TD CLASS="quote">i don't get ppl who do burnouts.. i hear ppl who drag say they do it to heat up the tires but you can just drive around for a few mins to heat them up. a waste of good tires. well nothings funnier than watching ppl tryna burnout w/ open diff.</TD></TR></TABLE>
erm if you do a burn out it makes the rubber real hot basically like rubber cement makes for a better launch dirivng around for a while isnt gonna do it, its not the same thing
hey next time its your turn in line at the drag strip ask the guys to wait so you can drive around for a bit to warm up them tires
Old Nov 24, 2006 | 12:48 PM
JDMhondalude22's Avatar
you guys sure that this wouldnt be due to poor compression in his motor? think about it. idk, my car will sit on an incline just fine in any gear. h22a m2b4. idk. maybe the lsd makes a difference. ???
Old Nov 24, 2006 | 01:02 PM
Sakanora's Avatar
Default Re: (JDMhondalude22)
he said his car rolled a little and then stopped
it has nothing to do with the engine, only the transmission.
Old Nov 24, 2006 | 04:08 PM
mkazm83's Avatar
It rolled approx a foot before I it came to a smooth stop. Also, it felt as if the car wanted to roll forward when I initially took my foot off of the brake (left in gear no e-brake) so I made some forward motions and thats when it rolled forward, then stopped. I'm unsure of how far it would/wouldn't roll if left with the e-brake disengaged.
Mikey3000
Sep 24, 2007 08:17 AM
NerveAgent
Honda S2000
Feb 6, 2006 01:35 AM
crx_88_si
Jun 10, 2004 10:20 AM
ComingSoonNearYou
13
May 23, 2004 05:12 PM
io_burn
Apr 25, 2003 07:13 PM
