Taking off oil pans
Old May 9, 2002 | 03:51 AM
d0nkeyxPunch's Avatar
Banned
Default Taking off oil pans
I looked under my car and examined how to take off the oil pan. I know the first thing is to drain the oil, unscrew all the tiny bolts, change the oil pan gasket, and put the new one on. Is there anything else that I should be advised of? I mean, it seems too easy to be true. Auto shops was going to charge me $200 including the oil pan. Any advice on changing the oil pans would be very appreciated. Thanks.
Old May 9, 2002 | 04:14 AM
sohc_boy's Avatar
Default Re: Taking off oil pans (FastxCivic)
not really i think u got everything covered, sometimes the gasket can be pretty tough and actually kinda glues the pan to the block had it happen to me, what a pain in the a$$.
Old May 9, 2002 | 04:16 AM
Banned
Default Re: Taking off oil pans (sohc_boy)
Thanks for the reply. Do I need to rub the engine oil around the oil pan gasket like how you do to oil filters?
Old May 9, 2002 | 07:13 AM
sohc_boy's Avatar
nope, maybe a lil honda bond or blue glue.
Old May 9, 2002 | 09:25 AM
brcivic411's Avatar
honda bond.. and there's also a pattern for tightening down the bolts. i don't know how necessary it is, but better to be safe then sorry
Old May 9, 2002 | 11:29 AM
HENRY's Avatar
New User
I reused the original oil pan gasket. Just make sure you don't tear it when removing it. I then used Permatex copper gasket sealent and spread a generous portion around on the mating surface of the oil pan. No leaks. Remember to be careful with the bolts for the oil pan. It's easy to over-tighten and break off a bolt.
Old May 9, 2002 | 04:50 PM
Chiovnidca's Avatar
Default Re: Taking off oil pans (HENRY)
A new gasket would be recomended. They aren't very expensive.
Old May 9, 2002 | 06:33 PM
BreakStuff's Avatar
New User
make sure you remove the steel o-rings that sometimes attach themselves to the oil pan studs when removing he OEM gasket..
Old May 9, 2002 | 07:03 PM
Prelude Vtec 23's Avatar
Default Re: Taking off oil pans (Chiovnidca)
I would replace it as well and not reuse it.
Old May 9, 2002 | 09:28 PM
Banned
Default Re: Taking off oil pans (Prelude Vtec 23)
You guys mentioned honda bond. Do they sell those at the dealerships or at Pep Boys, Autozone, or Kragens? Also do I have to get a new steel-O rings when changing the oil pan? How long does it take? A whole day?
Old May 9, 2002 | 09:31 PM
BoM's Avatar
BoM
it gets messy!!!!!!
Old May 10, 2002 | 04:01 AM
sohc_boy's Avatar
honda bond at the dealership u can get permatex at pep boys, autozone, r&s strauss etc... either one would work well. it shouldn't take that long to do the pan maybe a couple of hours tops for a 1st try.
phelpsj2
Mar 9, 2010 12:16 PM
lazyxmofo
Aug 16, 2007 09:59 PM
Mattyg2
Aug 28, 2004 04:50 PM
swlabhot
Aug 21, 2003 04:38 AM
imported204
Apr 22, 2002 02:33 PM
