throwing codes....91 accord
Old Nov 23, 2006 | 07:47 AM
cbabyby's Avatar
Default throwing codes....91 accord
my girlfriend just bought a '91 accord...obd 0..i myself have a 93 civic obd 1 i was just wondering is there any tricks to see what code it is throwing other than buying one of those fancy computers at the auto parts store
Old Nov 23, 2006 | 10:49 AM
1slowhatchie's Avatar
Default Re: throwing codes....91 accord (cbabyby)
i have a 90 accord and i checked the codes the same way i would do to a newer civic.(the plug that is under the glove box)
Old Nov 23, 2006 | 10:00 PM
igotthaspirit's Avatar
Default Re: throwing codes....91 accord (1slowhatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowhatchie &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90 accord and i checked the codes the same way i would do to a newer civic.(the plug that is under the glove box)</TD></TR></TABLE>
Its the SCS connector. Turn the key to the off position. Jump the 2 pin connector located by the right side kick panel with a paperclip. Turn the key back to the ON position and count the blinks of the Check Engine Light. The long blinks indicate the first number of the code and the short blinks indicate the second number of the code.
Old Nov 28, 2006 | 08:23 AM
cbabyby's Avatar
Default Re: throwing codes....91 accord (igotthaspirit)
i looked under the glove box....i found three or four connectors and they are all plugged into some thing...am i supposed to unplug the one with only two wires....in my civic its a green two pin plug slipped into a rubber boot....nothing similar to the accord???? please help
Old Nov 28, 2006 | 06:06 PM
if i remember correctly the accords connectors are blue. yea there should be only two wires. it might be plugged into a boot or a holder of some kind, or just hanging loose in the kickpanel
Merlin13
Oct 29, 2018 05:01 PM
Azaria
Aug 17, 2018 11:59 PM
Rob!
Apr 9, 2004 04:40 PM
brcivic411
Dec 8, 2003 08:55 PM
