What distributor do I have???
Old Nov 23, 2006 | 06:39 AM
Azn Kenny's Avatar
Default What distributor do I have???
Motor is a '98 GSR in a '95 hatch, it's starting to squeal real bad so I'm replacing it but I want to make sure I buy the right one first, thanx guys.
Old Nov 23, 2006 | 07:00 AM
mmuller's Avatar
Mad Scientist
Default Re: What distributor do I have??? (Azn Kenny)
any b-series vtec will work. look by one of the legs; it should have the part# ; maybe TD44U or TD68U
Old Nov 23, 2006 | 07:17 AM
Azn Kenny's Avatar
Thanx Max, so it doesn't matter if it's OBDI or II?
Old Nov 23, 2006 | 07:21 AM
mmuller's Avatar
Mad Scientist
Default Re: (Azn Kenny)
obd1; 2 plugs in the harness for the dizzy= obd1.
Old Nov 23, 2006 | 01:14 PM
JDM94EG28's Avatar
Default Re: (mmuller)
THATS A OBD1 DIZZY
Old Nov 23, 2006 | 07:39 PM
Azn Kenny's Avatar
Ok I ran into another problem, got another working OBDI dizzy and put it on but when I have it all the way advance (tilted towards the firewall) I'm only at 4 degrees of timing, that's way retarded!
I've heard about swapping guts from an OBDII to an OBDI, is this possible and how do I do it?
Old Nov 23, 2006 | 09:42 PM
mmuller's Avatar
Mad Scientist
1st check your cam timing
Old Nov 24, 2006 | 05:02 AM
Azn Kenny's Avatar
Cam timing has not been messed with at all.
Old Nov 24, 2006 | 08:07 AM
mmuller's Avatar
Mad Scientist
well kenny; try another dizzy to see if thats it, but what im saying even though cam timing was not messed with it could be wrong from before.. unless you timed the car before and knew it was a 16+_2 degress
you can just use a whole obd2 dizzy; youll just have to repin the plugs. search here on h-t on how to do it; its around
Old Nov 24, 2006 | 08:13 AM
Azn Kenny's Avatar
Yeah the car was timed before and set at 16 degrees, after the new dizzy I can't get it any farther than 4 degrees.
I read about repinning it too but I will try another dizzy 2day, thanks bud.
Old Nov 24, 2006 | 04:17 PM
Azn Kenny's Avatar
Ok so now I've had TWO dizzys on there and the same problem! It won't let me advance it past 4 degrees of timing! WTF?!
Old Nov 25, 2006 | 12:39 PM
mmuller's Avatar
Mad Scientist
any news?
Old Nov 25, 2006 | 01:30 PM
DeadVet's Avatar
Ill bet money its because you dont have the timing light on the right spark plug wire. If you dont have it on number 1 you wont be able to time it correctly.
Old Nov 25, 2006 | 01:41 PM
Azn Kenny's Avatar
Car was timed with it on the #1 plug wire as it has been done countless times, I can easily tell the car's timing is retarded because the car pulls like crap and runs rich.
Old Nov 25, 2006 | 01:48 PM
DeadVet's Avatar
Well you are definately doing something wrong unless both distributors are bad which i doubt or your timing light is bad.
Old Nov 25, 2006 | 01:55 PM
Azn Kenny's Avatar
Exactly! I have no explanation of this...
SupraRXZ
Apr 3, 2006 07:12 AM
Origin
12
Feb 11, 2004 09:31 AM
JDMs1eeper
Oct 22, 2003 10:01 PM
lsvtec101
Mar 21, 2003 03:31 PM
