bad camseal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">like the name implies, it seals the head cover from the head itself.</TD></TR></TABLE>
yea but is there a reason y it leaks at the cam gear and no where else?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanej2 »</TD></TR><TR><TD CLASS="quote">yea...y</TD></TR></TABLE>
Did you put hondabond or RTV in the corners like you're supposed to when you put the valve cover back on?
If it's leaking, more than likely not. There's your problem.
Yank the cover off, clean the gasket of most of the oil as well as the head's mating surface, dap a small bead of orange RTV or some hondabond in the corners where your cam sits and call it a day.
That'll be $49.99 please.
trooper0641
25
May 11, 2004 04:32 AM
TypeR 01 886
Jul 22, 2003 10:19 AM
