cam seal leak help
Old Nov 22, 2006 | 06:07 PM
posHonda's Avatar
Default cam seal leak help
ok I personally would follow this: http://importnut.net/STRseal.htm
but my dad is insisting that we heat up the cam seal, than pry the old one out and when the new cam seal is hot enough it will stick right in(using an OEM one for a '94)...to me it sounds like a very stupid idea but he says thats the way to do it..soo i dont want any damage done to my gsr motor
Old Nov 22, 2006 | 06:20 PM
HONDACURA-DB8's Avatar
Default Re: cam seal leak help (iVteC_PoWeR)
Go with the instructions...
Old Nov 22, 2006 | 06:25 PM
Fat Chick Magnet's Avatar
there is a special torque spec for the bolts after your done and a special pattern to bolt down. i lost the link to team integra site on how to change cam plug.....can someone spare the link to this guy?
Old Nov 22, 2006 | 06:32 PM
coronadrinker's Avatar
Default Re: (dc2rtek)
dude the heating thing sounds like a horrible idea, i think the torque spec is like 25ft/lbs and you tighten from inside out. not sure though do dont flame me if im wrong
Old Nov 22, 2006 | 07:41 PM
Sam92Teg's Avatar
Never let your dad touch or drive your car again, lol.
Do yourself a favor, buy a Haynes manual for your car, they are less than $20 and at most autoparts stores. This manual will give you step by step instructions on most repairs needed and even engine rebuilding. Even if you know how to work on cars, this manual will give you the torque specs for every bolt on the car.
There is a write-up somewhere, do a search on cam seal, sometimes refered to as 'end plug'. It isn't that hard to pull the valve cover and exhaust cam plate, then the seal is held in place by the last cam holder.
mikeyleed
Jul 16, 2010 02:33 PM
gutted-dx
Oct 16, 2005 07:50 AM
pr0jectezek1el
Sep 30, 2003 10:44 PM
acy76
Sep 30, 2003 07:08 AM
2muchPSI
Mar 18, 2003 06:46 PM
