compression test numbers
Old Nov 22, 2006 | 03:09 PM
dbiker207's Avatar
Default compression test numbers
I just did a compression test and my numbers were cyl. 4: 286psi, cyl. 3: 280psi, cyl. 2: 280psi, cyl. 1: 280psi. My engine is a b18c1 with 11.6:1 static compression. i was just looking for some input as to what u think of these. I beleive there pretty good, especially the only 6 psi variance.
Old Nov 22, 2006 | 03:43 PM
threeplugs's Avatar
Default Re: compression test numbers (dbiker207)
Thats a completely healthy motor.
Old Nov 24, 2006 | 07:58 PM
EFsSuck's Avatar
Default Re: compression test numbers (threeplugs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by threeplugs &raquo;</TD></TR><TR><TD CLASS="quote">Thats a completely healthy motor.</TD></TR></TABLE>
Old Nov 25, 2006 | 01:45 PM
BearsEK-KMSU's Avatar
Default Re: compression test numbers (EFsSuck)
what cams, and that seems like more like 12.7/1 compression, 300 is about 13/1 with most decent cams. did you check it wide open about 5 pumps
Old Nov 25, 2006 | 04:26 PM
IntegraType-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbiker207 &raquo;</TD></TR><TR><TD CLASS="quote">I just did a compression test and my numbers were cyl. 4: 286psi, cyl. 3: 280psi, cyl. 2: 280psi, cyl. 1: 280psi. My engine is a b18c1 with 11.6:1 static compression. i was just looking for some input as to what u think of these. I beleive there pretty good, especially the only 6 psi variance.</TD></TR></TABLE>
i'm 250 across the board, when engine is cold, when the engine is warm i hold 265 across the board, mugen 1 layer HG, ferrea high compression flat face valves, jdm b18c head on a 97 usdm type-r bottem end, i'm told i'm somewhere around 11.6:1 ~ 11.8:1 ..i'm sure your numbers are about right infact, ur compression might be alittle bit higher then what you think.
Old Nov 26, 2006 | 06:53 AM
dbiker207's Avatar
Default Re: compression test numbers (bearsEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bearsEK &raquo;</TD></TR><TR><TD CLASS="quote">what cams, and that seems like more like 12.7/1 compression, 300 is about 13/1 with most decent cams. did you check it wide open about 5 pumps</TD></TR></TABLE>
im using blox hsl cams and i did that on 9 cranks for eace cylinder, after 5 cranks it was between 275psi and 270psi for all 4 cylinders. and yes i did it under wot.
Old Nov 26, 2006 | 07:10 AM
si0385.'s Avatar
werd
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
duneracer69
Jul 27, 2007 04:08 AM
boosted k20
Apr 21, 2005 04:55 PM
snowblind7x
Apr 13, 2005 08:12 PM
Mr.Integra
Apr 22, 2004 07:55 PM
