fuel filter washer & bolts... quick question
i bought my fuel filter from autozone, and it came with 2 gold washers, which way do they go on the 15mm bolt? do they stack on top of each other? i can't remember where they go.
also the oem washers that were there were a little thicker then the ones from autozone, should i reuse the washers, or just use the new ones?
word. well is that diagrahm correct? i just wanted to make sure. cause i can't remember which way they go
also.. do i even use that small washer? or do i just use those 2?
I need to replace mine, my gas mileage is horrible.. Where is the fuel filter located.. I looked in my engine bay and couldnt seem to find it.. or maybe im retarded.
yeah it was really small, i figured it might not have been used, cause since i got it at autozone, it was probably a universal fuel filter for most honda applications, so some may have been different.
also, i have an injen short ram intake, the filter is dirty as hell, could i just go to walmart and get a cone filter? are they made any different?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboixtc »</TD></TR><TR><TD CLASS="quote">yeah it was really small, i figured it might not have been used, cause since i got it at autozone, it was probably a universal fuel filter for most honda applications, so some may have been different.
also, i have an injen short ram intake, the filter is dirty as hell, could i just go to walmart and get a cone filter? are they made any different?</TD></TR></TABLE>
most likly wont flow as good..
and you can wash those filters
ok there are 2 washers, 1 goes on the banjo bolt first then put the bolt through the gas line then put another washer on the bolt then put it on the filter heres a crappy diagram
bolt---washer----fuel line---washer---filter
get it?
and tighten it real good cuz it will leak if you dont but dont overtighten it
get it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteMW »</TD></TR><TR><TD CLASS="quote">I need to replace mine, my gas mileage is horrible.. Where is the fuel filter located.. I looked in my engine bay and couldnt seem to find it.. or maybe im retarded. </TD></TR></TABLE>
Its hidden behind the intake arm bolted onto the firewall.
i tightened it really hard. i almost sorta stripped the bolt that goes to the fuel filter, but the one that goes from the filter to the fuel rail, was tighted alot too, so i just changed it, i'm gonna buy the K&N air filter clean kit, and just clean the one i have now.
hondacivic97si
10
Mar 5, 2015 09:30 AM
Mini-mEK4
14
Jul 18, 2004 10:43 AM
civbeater90
Oct 25, 2002 03:14 PM
