Suspension Questions
Old Nov 22, 2006 | 06:35 AM
M1SCO15's Avatar
Default Suspension Questions
I have lowering spring on my car eibachs to be exact and my car is now lowered 1.8 inches... if i were to buy new shocks and struts would it lower my car even more or just make it handle better?
Also if i were to put a swap in my car would i have to change the shocks/struts on my car also?
Old Nov 22, 2006 | 06:47 AM
chingpo05's Avatar
Default Re: Suspension Questions (M1SCO15)
not lower more but itll handle alot better ( stiffer ride and not as bouncy)
Old Nov 22, 2006 | 07:09 AM
hondaman86's Avatar
Default Re: Suspension Questions (chingpo05)
Depends what you replace them with, if you go with OE style struts than there is no improvement, I would recommend kyb or tockico struts for improved driveability.
No, struts won't lower the car any more, and No, you don't need to replace struts when swapping motors.
Old Nov 22, 2006 | 07:41 AM
D16SohcVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M1SCO15 &raquo;</TD></TR><TR><TD CLASS="quote">I have lowering spring on my car eibachs to be exact and my car is now lowered 1.8 inches... if i were to buy new shocks and struts would it lower my car even more or just make it handle better?
Also if i were to put a swap in my car would i have to change the shocks/struts on my car also?</TD></TR></TABLE>
No replacing struts/shocks won't lower your car it just allows it to handle a lot better by eliminating bouncing and keeping the wheels to the ground. They type of struts/shocks to get is determined by your driving style. I went with Tokico HP series with a 2.5 inch drop and I'm not complaining about it. But if you do all around driving track, autocross, etc. Probably should go with an adjustable set.
808k20hatch
Suspension & Brakes
Oct 28, 2006 11:52 PM
nuggets
Sep 3, 2006 07:23 AM
dailygirl
Jun 13, 2004 03:39 PM
drunknmunkypow
Mar 24, 2003 12:33 PM
DC Sports EJ8
Dec 30, 2002 10:54 AM
