steel braided or high temp hose?
Old Nov 22, 2006 | 06:19 AM
blakacintegra's Avatar
Default steel braided or high temp hose?
i got a high temp black rubber fuel hose from auto zone and i was wondering if this will hold up good enough for the line from the turbo to the oil pan or am i def supposed to use a steel braided since its right next to the downpipe..if so is there any kind of heat resistant tape that i can wrap around it like the shiny crome tape people use for duct work or anything like that?? or am i just gona have to find a steel braided line,,if so where do you guys get these? thanks
Old Nov 22, 2006 | 06:45 AM
how much for a steel braided line with the 1/2inch fittings that i would need just from the turbo to the oil pan?
Old Nov 22, 2006 | 07:08 AM
i dont really know what your asking , i can get a pic up of what i have so far in a little while maybe that would be better?
Old Nov 22, 2006 | 07:14 AM
heres what i have...
Old Nov 22, 2006 | 07:18 AM
Old Nov 22, 2006 | 07:39 AM
HiProfile's Avatar
Default Re: (blakacintegra)
Why would you use a barb after an AN fitting? I'm 99% sure that alum adapter has 1/2" NPT threads, in which case you could have used a male npt to barb fitting to go right from turbo to hose.
I'd really suggest SS lines, since you can usually find them at speed shops in small lengths for not very much. Unlike most cheap hoses, SS lines are usually rated for oil and high temps. You also reflect a bunch of the turbo's heat away from the oil & rubber inside.
Old Nov 22, 2006 | 07:50 AM
i have no idea what your talking about, what else could i have done? my turbo came with that outlet, i found a barb that fit it found a high temp hose to fit the nipple on the barb and the hose fit perfect with the barb i have on my oil pan..
Old Nov 22, 2006 | 08:30 AM
N20civicB18's Avatar
contact stan @ fast-turbo
Old Nov 26, 2006 | 01:29 PM
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blakacintegra &raquo;</TD></TR><TR><TD CLASS="quote">i have no idea what your talking about, what else could i have done? my turbo came with that outlet, i found a barb that fit it found a high temp hose to fit the nipple on the barb and the hose fit perfect with the barb i have on my oil pan..</TD></TR></TABLE>
see the crome outlet on the turbo...then the blue an fitting...then you go to a male female barbed fitting....what he was saying is you could elimnate the blue fittin all together...and get a male barbed fitting to go straight into the crome fittin on the turbo....more than likely the fittin you bought isnt going to seal well against the an fiting and cause slight leaks....so youd be better off removing the blue and finding a fittin to match right into the crome piece...
djnikko
Oct 23, 2014 04:26 AM
bayoufrogg
Aug 26, 2005 01:04 PM
Black R
Feb 20, 2005 03:12 PM
reignofchaos
Jul 27, 2003 10:34 AM
jdmtegxsi
Jan 20, 2003 03:36 PM
