engine obd...? help
Hey guys,
I have searched but couldn't find the page that tells you what obd your engine is. I'm asking because I bought a jdm b18c that came out of a 93 teg, but it came with an obd2 loom and ecu. I'm wondering if the engine is obd2 aswell. The # on it is 1104103. Perhaps they changed in a newer engine at some stage? Any help would be great.
Cheers Greg
Cheers Greg
Thanks for answering man. I just had a quick look and the dizzy has one plug and the injectors have normal plastic clips with no metal retainer.
Modified by NZDelsoldude at 12:13 AM 11/22/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">Did B18Cs even come out in 93 models?</TD></TR></TABLE>
I'm not sure, I always thought it was 1994 and up (dc2). But I'm in NZ and we get all JDM cars, which may have had them earlier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">dont OBD-2 engines have 2 oxygen sensors? If one was missing, you'd be throwing a code.</TD></TR></TABLE>
I havent wired the engine up yet. My delsol has two oxygen sensors though and that is a 1992.
But the 02 sensors aren't on the engine
unless of course the swap was shipped here with half the exhaust still attached.
edit: OBD2 JDM ECUs do not look for two 02 sensors either.
unless of course the swap was shipped here with half the exhaust still attached.edit: OBD2 JDM ECUs do not look for two 02 sensors either.
Where getting off track here anyway. It seems that the b18c started comming out in integras after may 1993. So it could possibly be from that. However, everything else points to it being an obd2 engine and loom. Also one of the engine mounts that came with it looks custom made from aluminium. So do guys think that the engine was changed at some stage then? I thought my first swap would be straight foward
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostonjuice »</TD></TR><TR><TD CLASS="quote">cool</TD></TR></TABLE>
thanks for your input
B18c was not sold in anything until 94 model year.
usdm got the B17a1, and JDM got the B16a.
if it has 1 dizzy plug it is obd2.
either way, it doesnt really matter if you have the complete harness that went to the motor, it will plug right into your del slow car harness, but you will need an OBD1 P72 or equivelant ecu to run it as an obd1 swap.
Tundatoe
Jun 5, 2005 10:10 AM
