obd1 injectors in obd2 engine help!
I need to know if i can use obd1 injectors in an obd2 engine. I have a b16 head on a gsr block with ls injectors and when the vtec kicks in the engine just starts sputtering so any help would be appreciated
Re: obd1 injectors in obd2 engine help! (JA_EH94)
the ONLY thing different between the obd1 and obd2 injectors are the black plugs, where the harness plugs into the injectors. obd1 has the little thing in the middle of the plug while obd2 has it towars one side. with ur setup u look like ur mechanically smart enough to make them work. once u see the difference in person, im sure u can make them work.
