5th gen Civic motor in a 2nd gen CRX... Wont start...
Old May 8, 2002 | 08:22 PM
enthusiast128's Avatar
Default 5th gen Civic motor in a 2nd gen CRX... Wont start...
I installed a 92 Civic Si VTEC motor in my CRX, and it wont start... It cranks, has fuel and spark... But it wont crack over... Anyone kno of this problem???
The distributor is from a 92 Civic Si, i rewired the connectors to the CRX harness... Matched each and every wire and still wont start... Please help me out, i really need my damn car to run... Thanx
Old May 9, 2002 | 10:38 PM
Default Re: 5th gen Civic motor in a 2nd gen CRX... Wont start... (J TAM 128)
anybody??? please i really need to get my car running...
Old May 9, 2002 | 10:53 PM
Kamin's Avatar
dont try a dist. from a crx
you probably wired it wrong.
Old May 10, 2002 | 05:49 AM
lelopez's Avatar
Check all your wiring again and make sure you get continuity from the ECU to the respective locations on the engine. Are you getting any codes? Might start there.....check for codes, I'm assuming you're running a p28 right? The ECU might tell you what's wrong with the vehicle.
Also, did you connect all the important grounds back? (like the one on the thermostat housing)
let us know, hope this helps.
L.
Old May 10, 2002 | 10:16 AM
Mista Bone's Avatar
D Tranny Guru
You have to use the CRX dist.........
92 Dist. doesn't work with the CRX ECU
Old May 10, 2002 | 02:29 PM
Default Re: 5th gen Civic motor in a 2nd gen CRX... Wont start... (C5_ALLMOTOR)
Im using the CRX ecu, didnt hook up any VTEC controller yet... My cousin said that i dont need it to get it running...
I cut off the CRX dist. connecter and rewired the 92 Civic Si dist. Am i doing something wrong here??? gotta go back and check the engine code again... Dont remember if any showed...
Old May 11, 2002 | 05:06 AM
Mista Bone's Avatar
D Tranny Guru
I repeat.....
<U>YOU HAVE TO USE THE CRX Distributor!</U>
Old May 11, 2002 | 09:01 AM
I will try that the next time i see my CRX... Thanx alot guyz...
Old May 14, 2002 | 10:26 PM
Is there a trick to get my car started??? Cuz i just tried the dist. from a CRX Si and still no go... Here is my previous post on how my car died down https://honda-tech.com/zerothread?id=126367
Old May 15, 2002 | 05:42 AM
lelopez's Avatar
Ok, as everyone has told you already: If you're using the CRX ECU, you need to use the CRX distributor and notch it so you can make it fit on the sohc vtec head (unless you have a d16y8 head).
Now, if you want to use the 92-95 vtec distributor, you need to run the p28 ECU where you'll have lots of fun (I know I did) converting from obd0 to obd1
Since you said you cut the plugs from the CRX dist. and put them on the VTEC dist, my bet is that when you went to put the plugs back on the CRX dist you wired something wrong. Make sure you double check everything and that you have continuity on the wires.
Are you getting fuel and spark? if you are, your problem may lie somewhere else, did you double check that the timing belt is on and aligns with all marks?
L.
Old May 15, 2002 | 06:59 AM
Default Re: 5th gen Civic motor in a 2nd gen CRX... Wont start... (lelopez)
I did use a CRX dist. still wont start.. Timing belt is installed correctly... I have used 2 CRX dist. and 2 5th gen dist. already and still no go...
Old May 17, 2002 | 01:00 PM
si foo's Avatar
yo Jim did u take my resistor box off the crx?
Old May 17, 2002 | 08:16 PM
dumbmadtech's Avatar
Default Re: 5th gen Civic motor in a 2nd gen CRX... Wont start... (si foo)
How did you mount the distributor? The CRX has like 28 teeth on the crank angle and the ex motor 32 teeth. You have to make sure that the tdc of both motors are the same so that the timing is on. the most likely thing is that your timing is outta whack. This swap is a tricky rig. The worst is you will never actually get the timing perfect. If you can return the motor and get a 96 and newer motor the distributor bolts right up. Also if you do this you will have a knocksensor and can buy a 1stgen b16 automatic computer. This setup hauls *** for a sohc vtec crx. Wher you stand right now its all about the timing and make sure you didnt mix up the two white wires in the distributor. This will stop it from cranking.
Old May 17, 2002 | 08:42 PM
Default Re: 5th gen Civic motor in a 2nd gen CRX... Wont start... (dumbmadtech)
kimmon- yes i did... thought that was the problem...
dumbmadtech- Thanks for the tip, i will try that tomorrow night... Keep u guyz posted...
Old May 17, 2002 | 08:48 PM
If you are really bored you can make the car OBD1 by using the 92 93 teg harness it not all together too hard. This opens you to a whole new world of tuning parts electronics wise.
Old May 18, 2002 | 01:32 AM
si foo's Avatar
can i get it back, cuz i need it bad so asap, give to my bro
Old May 18, 2002 | 05:42 AM
B16C-RXed's Avatar
Right on, I decided after talking to various people to just go newer and spend an extra couple of bucks, because it's a hell of a lot more compatable...Good luck...
rexneffect85
Mar 8, 2010 03:43 PM
4doorredeg8
Jul 7, 2006 11:47 AM
Xtream
Oct 23, 2003 05:22 PM
HondaPartsHero
Oct 2, 2003 08:50 PM
