can't decide... b18b or 16a
cant decide on which
b16a is cheap and is vtec but no torque
b18b is decent hp and nice torque
aahhhhhh.......
its going into eg
persuade me into something guys
share me your intellect
aahhhhhh.......
its going into eg
but the b16 has 111 lb of tq with 160 hp
b18b has less hp but more torque
i need more understanding about hp and torque
is too much or too less of each is good or bad?
and to add
what are the pros and cons of having vtec
[Modified by wheresmyvxhb, 12:10 AM 5/9/2002]
[Modified by wheresmyvxhb, 12:11 AM 5/9/2002]
and to add
B18B has 127 pounds of torque, 142 horses......... slap a turbo or supercharger on that bad boy and watch out! Oh did I just give my plans away??
LSVTEC? CRVTEC?
or save up alot more and drop a B18C5 (type r) engine in there.
if you go LS or LSVTEC OR CRVTEC...
at least get a GSR tranny...
Please do NOT get an LS tranny.
thanks...haha
thanks...haha
if you are going to use it in stock form you would probably be happier witht he b18b due to its torque. If you are planning on building it then the B16 is the way to go. F/I on either engine, stock, and it's a toss up. Most would say go B18B b/c of compression ratio... you can safely run more boost since it's lower, but.... the ability to do some internals on the b16 and you could have 9:1 or 9.5:1 je pistons with some nice turbo cams and have a streetable monster when you hit VTEC. My car screams when VTEC engages @ 5,800 RPM's.
These might be handy
http://ubermensch.org/Cars/Technical/hp-tq
http://www.rs-productions.com/RSP_Mo.../hptq/hptq.htm
HP vs Torque
HP vs Torque
EkTurboHatch
Aug 21, 2004 05:00 PM
