F/S: B Series Action Clutch, LS Head, Si Airbox, Misc D/B Series Stuff
Old Nov 21, 2006 | 05:55 PM
inspyral's Avatar
Default F/S: B Series Action Clutch, LS Head, Si Airbox, Misc D/B Series Stuff
This is an unsprung 6-puck Action 1MD clutch for B series hydro trannies. Clutch has ~10k miles on it and is in good condition. Features a single diaphragm heavy duty pressure plate, 6-puck solid disc with Miba friction pads, and is rated for 275HP. Thowout bearing and allignment tool included, but you'll probably want to replace the bearing. $175
JDM LS/CRV P75-2 head - Head stamp says it's a 96. Came off a JDM B20B with ~30k miles on it. Good condition, what you see is what you get. Make an offer
OEM 99-00 Civic Si Airbox/Intake Arm - Good condition, comes with genuine Honda replacement filter. Make an offer
This is a brand new and never used Earl's -10 45 degree Swivel Seal hose end. It retails for about $24. Get it here for $18.
B&M fuel pressure gauge - no fittings, just the gauge, SOLD
Generic single bend short shifter - should fit Civics and Integras, comes with some hardware, but you might need some extra washers/spacers, also might need to replace/lube the bearings, make an offer
OEM Rear LCA's - fit 96-00 Civics, make an offer
OEM springs - fit 92-00 Civics and 94-up Integras, make an offer
OEM Civic shifter arm - make an offer
D16Y8 starter motor - off a 97 EX MT, $50
D16Y8 Shift Linkage - comes with poly ES bushings, $30
D16Y8 oil pump - ~1000 miles on it, $30
D16Y8 internals - complete internals from my 97 shortblock, #3 piston has cracked ringlands, make me an offer
D16Y8 backup light switch - $15
D16Y8 crank pulleys - 2 available, make an offer
D16Y8/B18B engine mounts - D16Y8 AC mount, front tranny mount, upper tranny mount(on chassis), rear chassis mount, rear tranny bracket; LS front torque mounts(on chassis); make an offer an any or all
98 LS power steering pump, pulley, belt(not pictured because I have several belts lying around and I don't know which one it is), bracket - 60k miles, make an offer
98 LS clutch disc, pressure plate - Very low miles, a lot of meat left, make an offer
98 LS clutch slave cylinder with some brackets and lines - make an offer
98 LS flywheel - good condition, make an offer
98 LS fuel pump - 60k miles, make an offer
98 LS intake manifold bracket - make an offer
________________
Buyers pay shipping costs on all items, unless otherwise noted.
I prefer not to ship the heavier/bulkier items for obvious reasons.
All parts listed are from a 97 Civic EX or 98 Integra LS, unless otherwise noted.
I'm in San Jose, Cali.
Modified by inspyral at 3:21 PM 11/23/2006
Old Nov 23, 2006 | 03:46 PM
flatblack-h22's Avatar
Default Re: F/S: B Series Action Clutch, LS Head, Si Airbox, Misc D/B Series Stuff (inspyral)
10$ 30043
Old Nov 27, 2006 | 08:25 PM
Old Nov 28, 2006 | 03:52 PM
inspyral's Avatar
Default Re: F/S: B Series Action Clutch, LS Head, Si Airbox, Misc D/B Series Stuff (mr.EGg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.EGg &raquo;</TD></TR><TR><TD CLASS="quote">98 LS clutch slave cylinder with some brackets and lines - make an offer
10$ 30043</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.EGg &raquo;</TD></TR><TR><TD CLASS="quote">???</TD></TR></TABLE>
I'll pass on that offer, thanks though.
Old Nov 30, 2006 | 12:26 PM
Default Re: (inspyral)
well how much then? i need that line
Old Nov 30, 2006 | 06:22 PM
tha_badguy's Avatar
si airbox still 4 sale?
Old Dec 2, 2006 | 05:12 AM
Sikocivic's Avatar
PM sent
Old Dec 10, 2006 | 01:40 PM
inspyral's Avatar
<FONT COLOR="crimson">w00t!</FONT>
Old Dec 12, 2006 | 06:36 PM
i just need the bracket and lines, lmk!
levee000
Jan 30, 2008 04:44 AM
slammedEM1Si
Sep 9, 2007 11:53 AM
inspyral
Dec 10, 2006 01:43 PM
inspyral
Northern California (Sales)
Dec 10, 2006 01:39 PM
skribblah
13
May 6, 2003 10:17 AM
