how much of a power gain is there going form 87 octane to 93 octane....
Old May 8, 2002 | 07:39 PM
CrOmEdOmEcHaMbEr's Avatar
Default how much of a power gain is there going form 87 octane to 93 octane....
I was just curious about how much of a gain i can expect on a stock motor from switching fuels
Old May 8, 2002 | 07:48 PM
00-ITR-373's Avatar
Default Re: how much of a power gain is there going form 87 octane to 93 octane.... (CrOmEdOmEcHaMbEr)
None. it will only guard against detonation. Higher octane will not detonate as easily, allowing you to run higher compression, or more boost. So, unless you are detonating, there is really not much benefit to upping octane.
Old May 8, 2002 | 08:07 PM
slooowDX's Avatar
Default Re: how much of a power gain is there going form 87 octane to 93 octane.... (00-ITR-373)
some lower comp motors run a lot better off of 87... the 91 is too hard for the motor to burn...
Old May 8, 2002 | 09:03 PM
kane2g's Avatar
Default Re: how much of a power gain is there going form 87 octane to 93 octane.... (slooowDX)
You need it when you have Turbo/SC/NOS/High Compression. Any other time just use whats recomended
Old May 8, 2002 | 09:07 PM
supergreenNA1's Avatar
New User
higher octane gasoline burns slower.. therefore there is absolutely no performance gain by using it unless your engine setup requires it. use the lowest octane fuel you can get away with.
Old May 9, 2002 | 07:49 AM
Default Re: how much of a power gain is there going form 87 octane to 93 octane.... (supergreenSol)
will u get any better milage out of it?
Old May 9, 2002 | 08:16 AM
E. Honda's Avatar
What fuel should you run on a B16a2? I always run 92,
Old May 9, 2002 | 08:32 AM
samdawgsol's Avatar
New User
Default Re: how much of a power gain is there going form 87 octane to 93 octane.... (CDM SiR)
92 octane burns hotter i think than 87, but ya I agree totally with guys above on detonation. It seems to me it a tank of premium doesnt last as long as regular. But maybe i just drive it differently.
Old May 9, 2002 | 11:20 AM
E. Honda's Avatar
Default Re: how much of a power gain is there going form 87 octane to 93 octane.... (samdawgsol)
Once again does anyone know What fuel should you run on a B16a2? I always run 92,
Old May 9, 2002 | 11:27 AM
Kamin's Avatar
yes 92 in a b16 motor.
Old May 9, 2002 | 11:41 AM
Boo Boo'n's Avatar
Default Re: how much of a power gain is there going form 87 octane to 93 octane.... (KAMiN)
is 87 is a 98' EK good? DX
flat out 99
Jan 17, 2012 02:32 AM
SoFresh1189
Jan 26, 2010 02:32 PM
teg your it
Apr 23, 2005 02:06 PM
JDM2ndGen
Mar 2, 2004 06:48 PM
ingrate
Jul 16, 2001 06:44 PM
