egr valve????
Old Nov 21, 2006 | 01:28 PM
mrmckie's Avatar
Default egr valve????
Watup gurus. just a few questions.
Whats is an egr valve, what does it do/control, and what kinda emissions related problems can it cause? (i've been told my car failed emissions because of this )
If anyone has a pic that would be real helpful or even a link to a helms manual that i can download, it would be gretly appreciated.
thanks
ps: 94 gsr (the bucket, wooo!!!)
Old Nov 21, 2006 | 02:13 PM
igotthaspirit's Avatar
Default Re: egr valve???? (mrmckie)
Exhaust Gas Recirculation Valve
I reroutes a small amount of exhaust gas back thru the combustion chamber again to burn off any leftover oxygen. If your car failed emmisions because of it, its likely the valve stuck open and is letting too much exhaust gas back into the combustion chamber. Time to go junkin!
Pic.
http://z.about.com/d/autorepai...b.gif
Old Nov 21, 2006 | 02:29 PM
thesmogman's Avatar
EGR = Exhaust gas recirculation
It returns burnt gases(Exhaust) back into the intake manifold to lower combustion temperatures.
Four things need to be checked for.
1. Signal from ecu to vac solenoid
2. Vacuum from solenoid. Should be at 7 in.hg
3. EGR valve is not stuck
4. Ports in intake manifold. Usually plugged up from carbon.
EDIT:It is designed to reduce Nox, But when it is not operating properly it can raise CO also.
Modified by thesmogman at 4:03 PM 11/21/2006
Old Nov 22, 2006 | 06:09 AM
mrmckie's Avatar
thanks guys
Old Nov 25, 2006 | 02:51 PM
frostyrb's Avatar
Default Re: (mrmckie)
Does the GSR even use an EGR? I thought the vtec took care of the EGRs job?
Old Nov 25, 2006 | 03:24 PM
nitrofish420's Avatar
Default Re: (frostyrb)
VTEC has nothing to do with EGR. And GSR's don't have EGR systems, nor do most Civics and Integras.
H22_CB7_JAY
May 1, 2012 12:29 PM
Master23
Aug 5, 2010 08:34 AM
mrmckie
Oct 20, 2007 11:28 AM
rody084
May 10, 2003 08:05 PM
