ls into a 1998 civic
Old Nov 21, 2006 | 09:56 AM
ar3dd's Avatar
Default ls into a 1998 civic
planning on lsv but just wanted to straighten out what i will need for a swap....
i was told i can keep my oem engine mounts....i near a si rear bracket and >>timing belt bracket??<<...and can use axles out of the 1990 teg that im gettin engine from
thats what i no.. but was curious what the harness is out of the ls? odb-0? and i can use that harness on my civic?
please share your knowledge
Old Nov 21, 2006 | 10:15 AM
bond007's Avatar
Default Re: ls into a 1998 civic (ar3dd)
I dont even know where to start ,those six letters at the top right hand corner of your screen is your best friend if not prepare to get flamed whenever you post,good luck
Old Nov 24, 2006 | 03:31 PM
ar3dd's Avatar
thanx i guess?..bump.. just want to clearup info i heard...another question i had was if i could use Da axles on my 98 EK or they have to be Dc?...and dont tell me to search please cause i alredy tried
Old Nov 24, 2006 | 03:56 PM
pdiggitydogg's Avatar
em1 timing bracket
em1 rear T bracket
front lower B transmission bracket
stock civic rubber mounts ok
axles from 94-01 b series only, including 1/2shaft
use your stock civic wiring harness, but extend a few things (like iat)
youre going to hate that obd0 ls head and intake manifold....
you didnt search hard enough
92integra-R
Mar 20, 2007 09:06 PM
Ha Itz
Nov 20, 2006 06:06 PM
Ha Itz
Nov 14, 2006 05:28 PM
cbmprelude
Nov 30, 2005 07:15 AM
benjamin
Dec 20, 2004 08:54 AM
