Sohc Heads Plz Head...D16y7 In 93 Ej1 Ex-Not Starting *Searched*
Old Nov 21, 2006 | 04:37 AM
GoHardEH2's Avatar
Default Sohc Heads Plz Help...D16y7 In 93 Ej1 Ex-Not Starting *Searched*
I really need some help to finish this up..I want get it to start it today
1st off I did search and i didnt get what i was looking for this is my daily i really need help-Thanks in advance
My Set-up
D16y7 longblock
z6 tranny
obd1-injectors
obd1 alternator
What distributor and Ecu do I use? i have a p28 and i used a dx dizzy
I have spark and fuel
If my alternator Belt is a lil slack,that would affect the starting process right?I was told no but im goin to tighten after school
Modified by UpNCominEJ1 at 9:08 AM 11/21/2006
Old Nov 21, 2006 | 05:29 AM
malubawla's Avatar
Default Re: Sohc Heads Plz Help...D16y7 In 93 Ej1 Ex-Not Starting *Searched* (UpNCominEJ1)
you have to reuse your z6 intake manifold and tb....also, you have to change the plug over from the OBDII dizzy, to your stock OBDI harness...use a OBDI PO6 ecu
Old Nov 21, 2006 | 05:42 AM
GoHardEH2's Avatar
Default Re: Sohc Heads Plz Help...D16y7 In 93 Ej1 Ex-Not Starting *Searched* (malubawla)
Thanks alot...With the plugs i can jus strip and solder them back on rite?
Old Nov 21, 2006 | 05:48 AM
GoHardEH2's Avatar
Will Any other distributor work?
Old Nov 21, 2006 | 07:04 AM
malubawla's Avatar
yeah make sure you solder them dont be ghetto and tape them.....you need to use a SOHC OBDII dizzy
Old Nov 21, 2006 | 07:55 AM
GoHardEH2's Avatar
What else could it be if it does start? Will a P28 be ok to use for right now?
Modified by UpNCominEJ1 at 9:32 PM 11/21/2006
88turdbucket
May 10, 2007 05:09 PM
GoHardEH2
Nov 23, 2006 01:16 PM
tshuajzoo559
Aug 19, 2006 03:00 PM
hAcHiEeg6
Oct 20, 2005 05:00 PM
JCracer723
Apr 24, 2003 12:06 PM
