Sohc Heads Plz Head...D16y7 In 93 Ej1 Ex-Not Starting *Searched*
Sohc Heads Plz Help...D16y7 In 93 Ej1 Ex-Not Starting *Searched*
I really need some help to finish this up..I want get it to start it today
1st off I did search and i didnt get what i was looking for this is my daily i really need help-Thanks in advance
My Set-up
D16y7 longblock
z6 tranny
obd1-injectors
obd1 alternator
What distributor and Ecu do I use? i have a p28 and i used a dx dizzy
I have spark and fuel
If my alternator Belt is a lil slack,that would affect the starting process right?I was told no but im goin to tighten after school
Modified by UpNCominEJ1 at 9:08 AM 11/21/2006
My Set-up
D16y7 longblock
z6 tranny
obd1-injectors
obd1 alternator
Re: Sohc Heads Plz Help...D16y7 In 93 Ej1 Ex-Not Starting *Searched* (UpNCominEJ1)
you have to reuse your z6 intake manifold and tb....also, you have to change the plug over from the OBDII dizzy, to your stock OBDI harness...use a OBDI PO6 ecu
Re: Sohc Heads Plz Help...D16y7 In 93 Ej1 Ex-Not Starting *Searched* (malubawla)
Thanks alot...With the plugs i can jus strip and solder them back on rite?
yeah make sure you solder them dont be ghetto and tape them.....you need to use a SOHC OBDII dizzy
What else could it be if it does start? Will a P28 be ok to use for right now?
Modified by UpNCominEJ1 at 9:32 PM 11/21/2006
GoHardEH2
11-23-2006 01:16 PM
JCracer723
04-24-2003 12:06 PM
