Vacuum Diagram for d16y8
I searched but couldn't find any diagrams for d16s any d16 vacuum diagram could help. I just need to make sure my intake manifold vacuums are correct... my car seems to be idling high.
but this could be because of my IACV.
Modified by TH33G4MON3 at 3:38 PM 11/21/2006
Anyone have a Chiltons? I have some other manual similar but it doesn't have the vacuum diagrams... I'm not sure if Chiltons does either but maybe.
i got a y8 to .. is it idiling high like just for a min then calms down to round 1200 rpm or is it constant.. if it is bogging in and out take a flat head and on top the throttle body there is a screw turn it to the right about a turn and see if the idel goes down any.. if it helps keep a eye on your tach and adjust it til its ideling round 800rpm..
if its not surging , just simply idling high , than its a vacuum leak for sure. get a intake manny cleaner , and spray it around all the vacuum connections , youl know when you find it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vahonda97 »</TD></TR><TR><TD CLASS="quote">i got a y8 to .. is it idiling high like just for a min then calms down to round 1200 rpm or is it constant.. if it is bogging in and out take a flat head and on top the throttle body there is a screw turn it to the right about a turn and see if the idel goes down any.. if it helps keep a eye on your tach and adjust it til its ideling round 800rpm.. </TD></TR></TABLE>
Its ideling high and just staying there... I'll try adjusting that screw. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cranny »</TD></TR><TR><TD CLASS="quote">if its not surging , just simply idling high , than its a vacuum leak for sure. get a intake manny cleaner , and spray it around all the vacuum connections , youl know when you find it.</TD></TR></TABLE>
I'll pick one up tomorrow. This sounds like it could be it. Thanks
nuclidex
Jul 20, 2014 04:30 AM
portaman03
Oct 16, 2008 11:58 AM
