oil pressure
Old Nov 20, 2006 | 11:21 PM
sasinorm01's Avatar
Default oil pressure
what is the oil pressure supposed to be at idle on z6 engine ...i just installed and oil gauge and its idles at 25 psi is that good or bad
Old Nov 21, 2006 | 12:33 AM
crxnj's Avatar
Default Re: oil pressure (sasinorm01)
isnt that a bit high? at idle (750rpm) ive seen most engines at about 15psi..maybe your talking about the startup high idle ?
Old Nov 21, 2006 | 01:40 PM
sasinorm01's Avatar
well after a while it goes down to about 20 psi so iguess its a little high...someone told me i had a bad tps sensor ..can effect the oil pressure
Old Nov 21, 2006 | 03:05 PM
dr_latino999's Avatar
Default Re: (sasinorm01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sasinorm01 &raquo;</TD></TR><TR><TD CLASS="quote">well after a while it goes down to about 20 psi so iguess its a little high...someone told me i had a bad tps sensor ..can effect the oil pressure</TD></TR></TABLE>
No
Oil pressure is directly proportional to RPM with bearing clearances factoring in for a set amount of loss or gain.
Old Nov 21, 2006 | 07:26 PM
jdm_ef9_b16's Avatar
mine on my sohc vtec and b16 have both been around 20-25 psi at idle., i wouldnt worry about it. some people say 10 psi for every 1000 rpm is good so at 1000 rpm 10 psi is good i guess, and 2500 psi 25 is good, i dunno. but you should be ok.
trulyshavedintegra
Dec 9, 2012 05:06 AM
dragvixen
Jul 10, 2009 11:20 AM
platinum00
May 14, 2006 06:40 AM
integra-modder
Jul 16, 2004 06:44 PM
ablangc
Oct 24, 2002 06:21 PM
