dash bord shakes when launching
Old Nov 20, 2006 | 09:22 PM
kleancivic's Avatar
Default dash bord shakes when launching
well just got a civic and my first time run it....i launched it and my tires started hopping and a friend of mine said that it might be that my flywheel needs to be resurfaced.............need your guys suggestions.........................
Old Nov 20, 2006 | 09:24 PM
H22A_EJ2's Avatar
Default Re: dash bord shakes when launching (kleancivic)
happens to my car all the time but I have an h22 in a ej and the mounts keep the motor very stiff so I feel some vibration but nothing out of this world.
what setup do you have?
Old Nov 20, 2006 | 09:26 PM
EGwhat!!!'s Avatar
Default Re: dash bord shakes when launching (H22A_EJ2)
thats normal on a civic with a swap if you want to reduce the wheel hop get a (i cant think of the name of that ****)
Old Nov 20, 2006 | 09:27 PM
H22A_EJ2's Avatar
Default Re: dash bord shakes when launching (EGwhat!!!)
front traction bar?
Old Nov 20, 2006 | 09:28 PM
EGwhat!!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A_EJ2 &raquo;</TD></TR><TR><TD CLASS="quote">front traction bar? </TD></TR></TABLE> yes that thing dam i couldnt remember what it was called
Old Nov 20, 2006 | 09:29 PM
H22A_EJ2's Avatar
what gen civic do you drive, what motor is in it, and if its swapped then what mounts are you using?
Old Nov 20, 2006 | 09:32 PM
cranny's Avatar
24.224.233.247
id say your front motor mount is beat out. maybe rear getting weak too.
Old Nov 20, 2006 | 09:35 PM
kleancivic's Avatar
i have a 93 civic ex with a d16yz motor......i have stock mounts and i have a stage 1 act clutch ..........
Old Nov 20, 2006 | 09:40 PM
Max Kling's Avatar
Its wheel hop.
It happens, if they dont spin then they will hop.
Old Nov 21, 2006 | 07:03 AM
cranny's Avatar
24.224.233.247
Default Re: (Max Kling)
spinning is what causes hop dude. and hop comes from the struts not having the damping force or engine mounts wore out.
Old Nov 21, 2006 | 07:08 AM
boosted_EM1's Avatar
Default Re: (cranny)
what suspension setup to you have?
Old Nov 21, 2006 | 08:36 AM
kleancivic's Avatar
Default Re: (00 Em1)
my car is sitting on neuspeed race springs..............
Old Nov 21, 2006 | 08:39 AM
SkankyEJ7's Avatar
Default Re: dash bord shakes when launching (cranny)
it happens everytime i shift, then it just spins
Old Nov 22, 2006 | 02:18 PM
Guvnor's Avatar
it could be your engine mounts are worn out. you can check them by holding the brake, and slowly pressing the gas then let off the gas real fast. see how much the engine moves. takes two people. dont give it to much gas or you will just torque the mounts, just a little bit see it if they move easy. if there real bad you can shake the engine by hand.
if there good, it could be your shocks.
Old Nov 22, 2006 | 05:09 PM
turtleman321's Avatar
my dirvers side mount was shot and when i would pull out my dash would shake hardcore. but when i fixed it didnt do it anymore then it usually did with my h22 mounts. also make sure ur not pulling out in 3rd gear lol. that will shake the dash pretty good if your not expecting it.
Old Nov 22, 2006 | 05:12 PM
deadline's Avatar
check mounts and suspension ..
Old Nov 22, 2006 | 05:15 PM
EFstyle's Avatar
lol wheel hop....completely normal....
Old Nov 22, 2006 | 05:27 PM
jdmjaser's Avatar
Default Re: (EKEJ6)
yeah normal! i use to get it hella bad..
Old Nov 22, 2006 | 07:12 PM
I.C.C.'s Avatar
Default Re: (jdmjaser)
it just means you arent making enough power... make more power so it will just spin and the wheel hop will go away
in all seriousness, the front traction bar will help alot...
boostfed-r
Apr 10, 2008 05:21 PM
Keeper1343
Jan 11, 2008 06:26 AM
B18c1vicrx
Aug 19, 2007 11:49 AM
94accordsedan
Jun 20, 2005 11:45 AM
EFing8
Oct 22, 2003 10:45 AM
