dash bord shakes when launching
well just got a civic and my first time run it....i launched it and my tires started hopping and a friend of mine said that it might be that my flywheel needs to be resurfaced.............need your guys suggestions.........................
Re: dash bord shakes when launching (kleancivic)
happens to my car all the time but I have an h22 in a ej and the mounts keep the motor very stiff so I feel some vibration but nothing out of this world.
what setup do you have?
Re: dash bord shakes when launching (H22A_EJ2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A_EJ2 »</TD></TR><TR><TD CLASS="quote">front traction bar? </TD></TR></TABLE> yes that thing dam i couldnt remember what it was called
what gen civic do you drive, what motor is in it, and if its swapped then what mounts are you using?
i have a 93 civic ex with a d16yz motor......i have stock mounts and i have a stage 1 act clutch ..........
it could be your engine mounts are worn out. you can check them by holding the brake, and slowly pressing the gas then let off the gas real fast. see how much the engine moves. takes two people. dont give it to much gas or you will just torque the mounts, just a little bit see it if they move easy. if there real bad you can shake the engine by hand.
if there good, it could be your shocks.
my dirvers side mount was shot and when i would pull out my dash would shake hardcore. but when i fixed it didnt do it anymore then it usually did with my h22 mounts. also make sure ur not pulling out in 3rd gear lol. that will shake the dash pretty good if your not expecting it.
Re: (jdmjaser)
it just means you arent making enough power... make more power so it will just spin and the wheel hop will go away
in all seriousness, the front traction bar will help alot...
Keeper1343
01-11-2008 06:26 AM
