What is this called?
Old Nov 20, 2006 | 08:37 PM
dynamitezz's Avatar
Default What is this called?
I've researched and researched and I cannot find what this is exactly called but I'm sending my head out to hot tank and this little heater hose that goes to the head is jimmy rigged so I want to order new one but I don't know what it is called.
It is circled in red.
On another note, I finally found my source of misfireing. I checked this cylinder on a compression test and it had zero. This is why, notice the holes.
Old Nov 20, 2006 | 08:40 PM
downest's Avatar
First off, get some of this stuff.
What you have circled isn't a hose, it's a plug, I think it's the oil pressure switch that's normally under the dizzy?
Old Nov 20, 2006 | 08:42 PM
1 Fly SI's Avatar
Default Re: What is this called? (dynamitezz)
Isn't that a electrical plug? possibly temp sender. That would definatly give you bad compression.
Old Nov 20, 2006 | 08:43 PM
dynamitezz's Avatar
Default Re: (downest)
Oh well my mechanic who is doing it told me it is a heater hose running into the head, he said replace it so I thought that was it. Im a noooob sorry.
Old Nov 20, 2006 | 09:07 PM
KFBhonda's Avatar
Default Re: (dynamitezz)
yeah, that valve looks like some from my first engine project that i did about 8 years ago - rebuilding the head off my 89 integra
good luck
Old Nov 20, 2006 | 09:09 PM
dynamitezz's Avatar
Default Re: (KFBhonda)
Yeah man I'm hoping it runs alot better, it is getting hot tanked/milled. Replacing all new valves, seals, and gaskets. After this runs for a while it will be an engine swap so. I <3 my EF so I can't just see it go away because of this. Only has 148k so.
Old Nov 20, 2006 | 09:14 PM
nappyroots827's Avatar
yea that thing circled in red is the wire for you temperature sending unit for your guage....there is a heater hose that is near there, it goes from the head to the heater control valve, but what is circled def isn't a hose
KFBhonda's Avatar
cool. way to take care of the EF.
just make sure you get TDC in cylinder #1 right when you put her back together. have someone experienced help, if possible. i screwed it up on my old integra and the engine was shot and i wasted all my time and money... i was a super noob and i wasn't on honda-tech back then (was anyone?)
Old Nov 20, 2006 | 09:15 PM
dynamitezz's Avatar
Well lucky me I have a certified honda tech that is working side by side with me helping me so I learn my stuff. It is awesome experience
Old Nov 20, 2006 | 09:18 PM
ryanplayjoint's Avatar
The thing you circled looks like a one wire (yellow with green tracer) connector for the coolant temp. sensor that works the coolant temp gauge in your gauge cluster.
Old Nov 20, 2006 | 09:24 PM
Default Re: (ryanplayjoint)
Unless you are attempting to circle the heater hose behind it which can become a resident of hack city when being removed from a 16+ year old vehicle, in which case your tech. recommended replacement I would and get a factory honda clamp. You could put your freshly rebuilt dual point head on only to overheat because of the leaking heater hose. I also have to give you props for ripping that head off your self.
Old Nov 20, 2006 | 09:30 PM
dynamitezz's Avatar
The assistance of the honda tech there was nice because If I had any questions he answered them and showed me what to do. Its a learning experience
Old Nov 20, 2006 | 10:32 PM
djphonics's Avatar
Holy **** man. If your valve is that messed up on that cylinder, I can't imagine that the rings are in great shape either, but ya never know. Just something to think about. How many miles are on this engine?
Old Nov 21, 2006 | 03:43 AM
dynamitezz's Avatar
Default Re: (djphonics)
148,000
Old Nov 21, 2006 | 05:08 AM
TEXREX88's Avatar
Default Re: (nappyroots827)
148k is just getting broken in!! Should be great afterwards...Good luck..
Old Nov 21, 2006 | 07:09 AM
dynamitezz's Avatar
Default Re: (TEXREX88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEXREX88 &raquo;</TD></TR><TR><TD CLASS="quote">148k is just getting broken in!! Should be great afterwards...Good luck.. </TD></TR></TABLE>
That is what I'm hoping for!
Old Nov 21, 2006 | 07:11 AM
b18sihatch's Avatar
whats up with the pic of the heads valve that has a hole in it?
Old Nov 21, 2006 | 07:18 AM
dynamitezz's Avatar
Default Re: What is this called? (b18sihatch)
its a carbon deposit buildup that burned through the valve when cruising at 70 mph on the tollway.
hometheaterman
Apr 3, 2010 10:44 AM
hometheaterman
May 1, 2008 07:47 PM
cornhusker
May 21, 2004 08:24 PM
tek_civic
Aug 17, 2003 04:58 PM
typer_801
Feb 5, 2003 01:12 PM
