Brake Light Problem
Old Nov 20, 2006 | 04:27 PM
Jeff's Avatar
Banned
Default Brake Light Problem
So here's the situation I bought a car and the corner light was there as I drove away it flew off with the lightbulb assembly, Since then when I drive if I put my right flasher on the light flashs quickly, Then if I apply the brake's the right side doesn't work and the right flasher light on the dash stays on constantly till i let go of the brakes.
Now I haven't replaced the light connection in the front of the car, But I was wondering if that would effect the rear brakes also? If anyone has had this problem before please reply. Not one of the greatest problems to have. Thanks,
Old Nov 20, 2006 | 04:43 PM
CRISIS's Avatar
Default Re: Brake Light Problem (Jeff)
That is certainly one unique problem. I also have the fast blinking on my right side too. i've replaced ALL the bulbs, relays, fuses, almost went as far as to re-wiring everything. If I were you I would first look for fuse issues, then check your relay, and hopefully you get it fixed. Mine has been blinking like that for over a year.
Old Nov 21, 2006 | 08:22 PM
Jeff's Avatar
Banned
Well the flasher still blinks fast but I am missing a bulb. I fixed the brake lights and everything else tho. Freaking ground.
Old Nov 21, 2006 | 08:25 PM
GdmLaz's Avatar
it will flash fast if there is a bulb missing kinda like a warning letting you know that theres a bulb out or missin in ur case lol
Old Nov 21, 2006 | 08:28 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (GdmBlk99SI)
check ur grounds. replace the bulbs.. then come back!! let us know if its still doin it
Old Nov 22, 2006 | 03:45 AM
Jeff's Avatar
Banned
As I said I fixed the brake lights, The turn signal light will be fixed as of Saturday after I goto the Honda/Acura only scrap yard near my house. Inless I find some rare goodies.
Dark_Seraph_X
Sep 10, 2004 06:25 AM
JforJonathan
Mar 23, 2004 05:29 PM
FalconMan
May 8, 2003 03:51 PM
ponzarelli
Dec 30, 2002 10:42 PM
