Simply B16 or B18???
Old Nov 20, 2006 | 02:33 PM
uberdelsol's Avatar
Default Simply B16 or B18???
Just one simple question I’m getting a del sol with an imminent engine swap in mind and a plan for a turbo and in your opinion should I go B16 or B18 I’m a mechanic by trade so its not a problem either way I just put a B16 in my friends EK so I know the basics thank for your time and Knowledge and please reply.
Old Nov 20, 2006 | 02:35 PM
Nameless Warrior's Avatar
Default Re: Simply B16 or B18??? (uberdelsol)
Please provide more information.
B18....what? A1, C1, C5? What exactly are you trying to get at?
Old Nov 20, 2006 | 02:36 PM
Eran's Avatar
HT White Ops
B18Z5m + VTREK!
Old Nov 20, 2006 | 02:40 PM
dohcVTECeg2's Avatar
Default Re: (Eran)
im partial to b16's
Old Nov 20, 2006 | 02:53 PM
Bense's Avatar
simply nitrous?
Old Nov 20, 2006 | 02:54 PM
cambopheonix56's Avatar
Default Re: (dohcVTECeg2)
b18c1 with a b16 head with typeR valvetrain. Or just a b18c5 head.
Old Nov 20, 2006 | 03:01 PM
jdm_eg06's Avatar
Bone stock GSR, with type r tranny. (b18C1)
Old Nov 20, 2006 | 03:03 PM
Default Re: (jdm_eg06)
If you're gonna get a B16 you better boost that bitch. Cuz if you don't, its gonna be what it is...a bitch...at low end
Old Nov 20, 2006 | 03:08 PM
Default Re: (Nameless Warrior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior &raquo;</TD></TR><TR><TD CLASS="quote">If you're gonna get a B16 you better boost that bitch. Cuz if you don't, its gonna be what it is...a bitch...at low end </TD></TR></TABLE>
Don't forget to rev the hella **** out of it.
Old Nov 20, 2006 | 05:35 PM
petty$rep's Avatar
Default Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">b18c1 with a b16 head with typeR valvetrain. Or just a b18c5 head.</TD></TR></TABLE>
I think those are your two best options, and they will probably be the most fun. The reason i would not get a B16 is because it does not have very much torque (its basically a D16 that revs higher, has two cams, and a few more hp up top). If your going to get a B16 youd be better off just getting a D and boosting it, it will be much cheaper and yeild approx the same results
The good thing about a B16 head and and B18 block is you will get the best of both worlds, high reving and some good torque
it also depends on what you plan to do, N/A or F/I, this will help you make you decision by knowing which route your going to take.
Old Nov 20, 2006 | 06:09 PM
schardbody's Avatar
ls/vtec if boost is in the future why not get the best of both worlds, TQ, revs, cheap, reliable, and lower compression for those that dont like to pay for tuning.
Old Nov 20, 2006 | 06:43 PM
gottalovethe4door's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">ls/vtec if boost is in the future why not get the best of both worlds, TQ, revs, cheap, reliable, and lower compression for those that dont like to pay for tuning.</TD></TR></TABLE>
naylor16
Mar 15, 2007 04:38 PM
uberdelsol
Dec 2, 2006 12:07 PM
b16wanter
Jun 17, 2004 04:10 PM
jwrcivicdx
May 4, 2003 10:28 PM
