Simply B16 or B18???
Just one simple question I知 getting a del sol with an imminent engine swap in mind and a plan for a turbo and in your opinion should I go B16 or B18 I知 a mechanic by trade so its not a problem either way I just put a B16 in my friends EK so I know the basics thank for your time and Knowledge and please reply.
Re: Simply B16 or B18??? (uberdelsol)
Please provide more information.
B18....what? A1, C1, C5? What exactly are you trying to get at?
Re: (jdm_eg06)
If you're gonna get a B16 you better boost that bitch. Cuz if you don't, its gonna be what it is...a bitch...at low end
Re: (Nameless Warrior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior »</TD></TR><TR><TD CLASS="quote">If you're gonna get a B16 you better boost that bitch. Cuz if you don't, its gonna be what it is...a bitch...at low end </TD></TR></TABLE>
Don't forget to rev the hella **** out of it.
Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">b18c1 with a b16 head with typeR valvetrain. Or just a b18c5 head.</TD></TR></TABLE>
I think those are your two best options, and they will probably be the most fun. The reason i would not get a B16 is because it does not have very much torque (its basically a D16 that revs higher, has two cams, and a few more hp up top). If your going to get a B16 youd be better off just getting a D and boosting it, it will be much cheaper and yeild approx the same results
The good thing about a B16 head and and B18 block is you will get the best of both worlds, high reving and some good torque
it also depends on what you plan to do, N/A or F/I, this will help you make you decision by knowing which route your going to take.
ls/vtec if boost is in the future why not get the best of both worlds, TQ, revs, cheap, reliable, and lower compression for those that dont like to pay for tuning.
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">ls/vtec if boost is in the future why not get the best of both worlds, TQ, revs, cheap, reliable, and lower compression for those that dont like to pay for tuning.</TD></TR></TABLE>
