wiper switch problem
Old Nov 20, 2006 | 01:48 PM
kcjohnnyboy's Avatar
Default wiper switch problem
my intermittant wiper doesnt work, it works on high and low. i had like 10 different wiper switches off dx ex lx civic, but all of the wiper switchs do the same thing. so im guessing its not the switch. i was searchin but there wasnt much input on this situation. one guy said he had a hanging wire under the steering column, he grounded it and workjed fine. i looked at mine and found no loose wires or anything. i need some help, thanks
Old Nov 20, 2006 | 03:51 PM
97civicdx's Avatar
Default Re: wiper switch problem (kcjohnnyboy)
Maybe u need a new intermittent control box on the fuse panel.
Old Nov 20, 2006 | 07:45 PM
Default Re: wiper switch problem (97civicdx)
ill check that and i will let u guys know
Old Nov 20, 2006 | 07:53 PM
EJgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx &raquo;</TD></TR><TR><TD CLASS="quote">Maybe u need a new intermittent control box on the fuse panel. </TD></TR></TABLE>
hes right... i had the same thing happen to me.
Old Nov 20, 2006 | 11:58 PM
Default Re: wiper switch problem (USDMej1)
what does it look like and is it located on the other side of the fusebox
Old Nov 21, 2006 | 12:06 AM
fmrprojects's Avatar
do you have a cx hatchback. cause cx doesnt have intermittent, it only has low and high speed
Old Nov 21, 2006 | 04:19 AM
miahmouse's Avatar
small correction Integrated Control Unit...
but yeah, I didn't think the cx had intermittent
Old Nov 21, 2006 | 10:37 PM
Default Re: wiper switch problem (fmrprojects)
i have a vx, and does anyonre know if its located on the other side of the fusebox
Old Nov 21, 2006 | 10:42 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy &raquo;</TD></TR><TR><TD CLASS="quote">i have a vx, and does anyonre know if its located on the other side of the fusebox</TD></TR></TABLE>
Yes, unbolt the two 10mm nuts holding in the fusebox, and it's the rectangular grey (or white)box. I have a VX also, and upgraded to intermittent wipers. Really easy to install.
You need the ICU (Integrated Control Unit) along with the switch from the donor car.
Old Nov 22, 2006 | 06:29 AM
miahmouse's Avatar
Default Re: wiper switch problem (BlueIntegraBoy)
you don't have to unbolt anything, it clips into the back of the fuse panel... rectangular, either white, grey or black...
Old Nov 22, 2006 | 10:49 AM
Default Re: wiper switch problem (miahmouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse &raquo;</TD></TR><TR><TD CLASS="quote">you don't have to unbolt anything, it clips into the back of the fuse panel... rectangular, either white, grey or black...</TD></TR></TABLE>
Unless you're Mr. Fantastic, you'll need to unbolt the metal piece above the driver's legs and the fusebox to get to the ICU.
Old Nov 27, 2006 | 08:13 AM
miahmouse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Unless you're Mr. Fantastic, you'll need to unbolt the metal piece above the driver's legs and the fusebox to get to the ICU.</TD></TR></TABLE>
It's on the backside of the fuse panel and just clips in. I've removed mine without unbolting anything.
edit:
look, clickypow of ICU.... with nothing removed. Unless you're an 800lb gorilla, you shouldn't have any problems...
Modified by miahmouse at 8:59 AM 11/28/2006
777sC
Aug 15, 2011 11:29 PM
misha
16
Mar 17, 2010 03:24 PM
scythe88
Oct 8, 2009 07:13 AM
FRKWOO
Aug 6, 2009 11:44 AM
go2sleep
Sep 2, 2007 10:08 AM
