wiper switch problem
my intermittant wiper doesnt work, it works on high and low. i had like 10 different wiper switches off dx ex lx civic, but all of the wiper switchs do the same thing. so im guessing its not the switch. i was searchin but there wasnt much input on this situation. one guy said he had a hanging wire under the steering column, he grounded it and workjed fine. i looked at mine and found no loose wires or anything. i need some help, thanks
Re: wiper switch problem (97civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx »</TD></TR><TR><TD CLASS="quote">Maybe u need a new intermittent control box on the fuse panel. </TD></TR></TABLE>
hes right... i had the same thing happen to me.
small correction Integrated Control Unit...
but yeah, I didn't think the cx had intermittent
Re: wiper switch problem (kcjohnnyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy »</TD></TR><TR><TD CLASS="quote">i have a vx, and does anyonre know if its located on the other side of the fusebox</TD></TR></TABLE>
Yes, unbolt the two 10mm nuts holding in the fusebox, and it's the rectangular grey (or white)box. I have a VX also, and upgraded to intermittent wipers. Really easy to install.
You need the ICU (Integrated Control Unit) along with the switch from the donor car.
Re: wiper switch problem (BlueIntegraBoy)
you don't have to unbolt anything, it clips into the back of the fuse panel... rectangular, either white, grey or black...
Re: wiper switch problem (miahmouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse »</TD></TR><TR><TD CLASS="quote">you don't have to unbolt anything, it clips into the back of the fuse panel... rectangular, either white, grey or black...</TD></TR></TABLE>
Unless you're Mr. Fantastic, you'll need to unbolt the metal piece above the driver's legs and the fusebox to get to the ICU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Unless you're Mr. Fantastic, you'll need to unbolt the metal piece above the driver's legs and the fusebox to get to the ICU.</TD></TR></TABLE>
It's on the backside of the fuse panel and just clips in. I've removed mine without unbolting anything.
edit:
look, clickypow of ICU.... with nothing removed. Unless you're an 800lb gorilla, you shouldn't have any problems...
Modified by miahmouse at 8:59 AM 11/28/2006
edit:
misha
16
03-17-2010 03:24 PM
FRKWOO
08-06-2009 11:44 AM
