My CTR Pistons Wont Fit My B16A2 Rods??
Old Nov 20, 2006 | 11:52 AM
SINBAD's Avatar
Default My CTR Pistons Wont Fit My B16A2 Rods??
I have new ctr pistons and they wont fit my b16a2 rods??
The rod is to wide at the top to fit up into the piston its self?
Do I need to shave the rods or the piston??
Old Nov 20, 2006 | 11:54 AM
Eran's Avatar
HT White Ops
Default Re: My CTR Pistons Wont Fit My B16A2 Rods?? (SINBAD)
I'm sure removing part of the rod would be the smartest possible thing you can do .... or you could buy new rods and rod bolts and upgrade out of necessity. But no, you're right, you should shave them. Structural integrity is for ricers.
Old Nov 20, 2006 | 11:57 AM
SINBAD's Avatar
Default Re: My CTR Pistons Wont Fit My B16A2 Rods?? (Eran)
So i should shave the rods and leave the pistons alone??
Old Nov 20, 2006 | 11:59 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINBAD &raquo;</TD></TR><TR><TD CLASS="quote">So i should shave the rods and leave the pistons alone?? </TD></TR></TABLE>
No, you moron. Obviously sarcasm is lost on you.
You need different rods.
Old Nov 20, 2006 | 12:01 PM
SINBAD's Avatar
So i should shave my RODS??
Old Nov 20, 2006 | 12:02 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINBAD &raquo;</TD></TR><TR><TD CLASS="quote">So i should shave my RODS??</TD></TR></TABLE>
<FONT SIZE="10">No.</FONT>
Old Nov 20, 2006 | 12:05 PM
mykoe817's Avatar
lol aha yeh man get new rods and bolts that fits it. you'll get a better yeild also.
Old Nov 20, 2006 | 12:08 PM
H9Omega's Avatar
Shaving the rod will not decrease structural integrity. This process is done alot on LS/VTEC setups and has yet to cause any problems as long you get it a reputable machine shop to do the precision machining.There are no other rods that will fit into your block and it is difficult to use for instance an eagle rod with a CTR piston, sure it can be done but that will be more expensive so.. HAVE YOUR RODS SHAVED PROFESSIONALLY AND YOU SHOULD BE OKAY!
Old Nov 20, 2006 | 12:09 PM
Eran's Avatar
HT White Ops
Default Re: (H9Omega)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H9Omega &raquo;</TD></TR><TR><TD CLASS="quote">Shaving the rod will not decrease structural integrity. This process is done alot on LS/VTEC setups and has yet to cause any problems as long you get it a reputable machine shop to do the precision machining.There are no other rods that will fit into your block and it is difficult to use for instance an eagle rod with a CTR piston, sure it can be done but that will be more expensive so.. HAVE YOUR RODS SHAVED PROFESSIONALLY AND YOU SHOULD BE OKAY!</TD></TR></TABLE>
Why is using an Eagle or TT rod with a CTR piston difficult?
Old Nov 28, 2006 | 10:17 AM
jdm_poompi's Avatar
i think u should use a b16b rod it will b beter
Old Nov 28, 2006 | 10:21 AM
Ricey McRicerton's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
Why is using an Eagle or TT rod with a CTR piston difficult?</TD></TR></TABLE>
Because it fits a smaller budget (aka the people using the shaved rods are probably on too tight a budget to really be replacing pistons in the car in the first place).
Old Nov 28, 2006 | 12:23 PM
doood's Avatar
been there done that
Default Re: (Ricey McRicerton)
you need to shave 1mm off each side of the small end of the rod. that's not a lot of material.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Why is using an Eagle or TT rod with a CTR piston difficult?</TD></TR></TABLE>
because stock rods use press fit wrist pins. aftermarket forged rods use full floating pins. you can make it work, but why not just upgrade to forged pistons at the same time?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_poompi &raquo;</TD></TR><TR><TD CLASS="quote">i think u should use a b16b rod it will b beter </TD></TR></TABLE>
those are too long
Old Sep 19, 2016 | 11:26 PM
Neilsolo's Avatar
If you are using oem rods from your b16a2, then you don't have CTR pistons, you have ITR pistons. CTR are drop in where as ITR are shave required.
StupidSlowRSX
Jan 27, 2005 08:37 PM
S10RALLYRACER
Aug 24, 2004 08:49 AM
vtec69
Aug 10, 2004 08:25 AM
milanoGSR
Jul 2, 2003 12:19 PM
vtec69
Jun 17, 2002 09:28 AM
