tial 38mm wastegate HELP!!!!!!
Old Nov 20, 2006 | 09:23 AM
crvtkllr's Avatar
Default tial 38mm wastegate HELP!!!!!!
i have a tial 38mm on my boosted b16. i recently had a boost leak and checked EVERYTHING and it still leaks boost only when i hit vtec. i have a turboxs dsbc. the top of the wastegate is vented to the atmosphere is that ok or should it be routed somewhere
HELP PLEASE!!!!
Old Nov 20, 2006 | 09:26 AM
BoostedEG6's Avatar
Default Re: tial 38mm wastegate HELP!!!!!! (crvtkllr)
have you checked all your couplings? I know they can tear and you wont notice it until you take them off and look at them. I dont think it has anything to do with the wastegate
morgan@synapse motorsport's Avatar
top port is for electonic boost controllers
Old Nov 20, 2006 | 09:32 AM
92redhatch's Avatar
check to see if you have a wastegate valve seat. The same thing happened to me and that was my problem. Titan motorsports sells them for like 20 bux.
Old Nov 20, 2006 | 09:34 AM
crvtkllr's Avatar
Default Re: (92redhatch)
it has all the parts it needs and no tears.
could it be the tuning since it only leaks in vtec?
Old Nov 20, 2006 | 10:23 AM
how exactly would tuning affect a boost leak? can u explain how its leaking, once vtec hits it just drops to 0? or does it slowly drop? did it always happen?
Old Nov 20, 2006 | 12:26 PM
tuned_vtec
Guest
Posts: n/a
I initially had problems getting the Tial to seal at high rpms. That stupid lip around the valve makes it difficult to keep it flat on the flange when you torque it down. To fix it once and for all I got the lip machined flat and sprayed all the surfaces with copper sealant. No more leak!!
Old Nov 20, 2006 | 01:40 PM
scartail's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">check to see if you have a wastegate valve seat. The same thing happened to me and that was my problem. Titan motorsports sells them for like 20 bux.</TD></TR></TABLE>
2X.
I would only boost like 3 psi. Making me think it was something else.
g2daturbo
Jun 2, 2008 03:45 AM
dangerranger21
Jul 5, 2006 10:00 PM
Cowboy
Jun 17, 2003 01:17 PM
blu_si
Oct 1, 2002 04:20 PM
whagkangmakulet
Oct 1, 2001 11:34 AM
