H22 head TROUBLES???
DOes anyone KNOW of a great honda head specialists in the SOUTHeast. Please respond
Curent diagnosis: A loss motion assembly (head makes a grinding noise at idle or when below 1000rpm) grinding noise reduces when engine is running above 1000rpm
Grinding started after the first pull on the dyno. Dyno sesssion stopped after the noise was detected.
Modified by peakboosth22 at 6:41 AM 11/22/2006
i'll check the dizzy. Is this issue common among h22?
What happens t0 the grinding noise level when the the rpms go up or down? OR does the noise level stay constant at any rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bond007 »</TD></TR><TR><TD CLASS="quote">Surprisingly I was having the same problem and it drove me crazy,like turboh22akkord
said its probably your dizzy</TD></TR></TABLE>
S1000RR
Dec 5, 2012 11:01 PM
