Fast idle due to advanced timing?
Old Nov 20, 2006 | 06:11 AM
NoVALude's Avatar
Default Fast idle due to advanced timing?
I took the Prelude to have the emissions tested and was told the idle was too high to run the test. Idles about 1600-1800 and have tried everything except replacing the IACV which is my last idea. Already did the fast idle adjustment here and checked for vacuum leaks quite a few times.
Emissions shop (down the road from my mechanic) suggested that the timing might be advanced causing the high idle. my mech. did the timing belt about 3 months ago and before he covered everything up I saw the cam gear marks and the alignment appears fine and the engine runs smooth....no sputtering or revving...just a high idle. after the IACV, I am out of ideas.
any suggestions?
Old Nov 20, 2006 | 06:13 AM
M2B4's Avatar
Default Re: Fast idle due to advanced timing? (NoVALude)
yeah the ignition timing is what hes talking about. my car was running like poop and idleing ruff. it was to reatrded. we got it at 15 and it idled a lil better. grab a timing light and check it. if it aint the problem no biggie it only takes a few mins to check.
Old Nov 20, 2006 | 06:22 AM
NoVALude's Avatar
Default Re: Fast idle due to advanced timing? (M2B4)
I tried to check the timing with a buddy of mine and we were not able to find any timing mark on the flywheel. fidanza model.
Old Nov 20, 2006 | 06:32 AM
M2B4's Avatar
well then mark on the dizzy where its at now and just move it w/o and see if idle eases up any if not put it back to your mark.
Old Nov 20, 2006 | 07:12 AM
NoVALude's Avatar
good suggestion. dropping it off tomorrow morning and will pass along to my mechanic.
just need to pass emissions to get my tags renewed!!!!
Hawkze_2.3's Avatar
Fidanza does have the timing marks but they are just little grooves. You're going to have to be very patient and turn the crank very slow to find them....I put dabs of paint on mine before I installed the flywheel and they're still not easy to see.
Old Nov 20, 2006 | 09:04 AM
NoVALude's Avatar
Default Re: Fast idle due to advanced timing? (Hawkze_2.3)
oh...good to know Hawkze... I will also mention that tomorrow as well.
thanks!
Old Nov 20, 2006 | 09:46 AM
mgags7's Avatar
having a dad that used to be a mechanic ftw
he has this long grabber tool and chalk setup that marks the flywheel nicely at those grooves
but yes having the timing too far advanced will up the idle, however it will not push it that high....what EMS are you running?
Old Nov 20, 2006 | 10:10 AM
NoVALude's Avatar
Default Re: (bb4ever)
P28 right now (hondata chipped)
Old Nov 20, 2006 | 10:15 AM
mgags7's Avatar
do you have any idea what is on the chip now?
there is a base idle setting...
Old Nov 20, 2006 | 10:21 AM
NoVALude's Avatar
Got the ECU directly from MT-BER..(John here on H-T). He set the chip and settings so I trust him...
I have a p14 here as well that I removed. Should I try that and see what the car at least idles at?
this is driving me nuts!!
Old Nov 20, 2006 | 10:58 AM
mgags7's Avatar
yea try the p14
Old Nov 20, 2006 | 11:02 AM
NoVALude's Avatar
edit: should have said that when shifting into neutral and letting off the throttle, the rpms dive to just under 1k rpms, and then climb to a steady 1600-1800. So it is almost as if the engine wants to idle correctly, but isn't. (?)
cool, I will take that with tomorrow and have the mech. try it.
Modified by NoVALude at 6:19 PM 11/20/2006
gooblinn258
Dec 12, 2013 06:21 PM
dc2LS
Jan 18, 2008 06:06 PM
civickiller
Feb 15, 2007 12:38 AM
AnAccordIsForever
Nov 25, 2006 09:23 AM
josephshark
Jan 2, 2006 11:52 AM
