EK9 swaybars
Old Nov 20, 2006 | 04:39 AM
KoRn_vIRuZ's Avatar
Default EK9 swaybars
Hey everyone!
Does anyone know the diameter of the EK9 front and rear swaybars?
Currently I have stock EK4 swaybars: 20 something at the front and 15mm.
Is it worth it to change and will the EK9 bars bolt in without problems?
I am a handling freak.
Thank you!!
Old Nov 20, 2006 | 04:51 AM
Bullitt's Avatar
Default Re: EK9 swaybars (KoRn_vIRuZ)
the EK9 have 26mm front and 22mm rear sway bars
The EDM EK4 (VTI) also have the 26mm front sway bar, but a smaller rear bar.
For the EK9 26mm front bar you will need the 99-00 Si front lower control arms, sway bar endlinks and the matching strut forks. The Ek9 bar is not compatible with EX LCAs
Old Nov 20, 2006 | 04:54 AM
kaiba's Avatar
Default Re: EK9 swaybars (Bullitt)
I wonder how is the EK4 subframe compare to our US civic 96-00.
Old Nov 20, 2006 | 05:00 AM
Bullitt's Avatar
Default Re: EK9 swaybars (kaiba)
The subframe of the EDM EK4 VTi is pretty much the same as the 99-00 Si in the States. Except that the VTi only came as a hatchback.
The LCAs, swaybars and brakes are the same.
I´m doing the sway bars and brake conversion on my EJ9 Hatchback right now.
Old Nov 20, 2006 | 06:21 AM
KoRn_vIRuZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bullitt &raquo;</TD></TR><TR><TD CLASS="quote">The subframe of the EDM EK4 VTi is pretty much the same as the 99-00 Si in the States. Except that the VTi only came as a hatchback.
I´m doing the sway bars and brake conversion on my EJ9 Hatchback right now.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bullitt &raquo;</TD></TR><TR><TD CLASS="quote">the EK9 have 26mm front and 22mm rear sway bars
For the EK9 26mm front bar you will need the 99-00 Si front lower control arms, sway bar endlinks and the matching strut forks. The Ek9 bar is not compatible with EX LCAs</TD></TR></TABLE>
Thanks very much for your replies!
But I am confused, if EK4 = 99-00 Si why would I need to buy 99-Si stuff?
What about the back, the most important, is it plug and play?
Please consider that I am from Portugal and that's where my Civic is, even though I am living in Japan now (and trying to get nice parts to take back home).
Sorry for all the questions and thank you for sharing.
Old Nov 20, 2006 | 09:16 AM
BlueIntegraBoy's Avatar
The VTi also came in a sedan too
Old Nov 21, 2006 | 05:52 AM
KoRn_vIRuZ's Avatar
Default Re: EK9 swaybars (BlueIntegraBoy)
Ok, so I got these EK9 swaybars for around 40€, it seemed a good deal.
Now I just need to figure out how to mount them...
Old Nov 21, 2006 | 06:29 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRn_vIRuZ &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so I got these EK9 swaybars for around 40€, it seemed a good deal.
You have all the mounting hardware you need. The only thing I'd get are some universal Energy Suspension swaybar bushings for the proper diameters, and make sure they come with new D-brackets.
Old Nov 21, 2006 | 11:33 AM
mr_nemesis2003's Avatar
^^Damn the rear sway looks thick, mine looks like a damn twig, lol.
Old Nov 21, 2006 | 11:41 AM
Harryflores's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">The VTi also came in a sedan too</TD></TR></TABLE>
I didn't know that !! good info
Old Nov 21, 2006 | 11:43 AM
Eran's Avatar
HT White Ops
Default Re: EK9 swaybars (Harryflores)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harryflores &raquo;</TD></TR><TR><TD CLASS="quote">
I didn't know that !! good info </TD></TR></TABLE>
VTi
VTi-S
VTi-R
VTi-RS
&lt;sarcasm&gt; Plus, the almight AWD RTi. &lt;/sarcasm&gt;
Old Nov 21, 2006 | 11:47 AM
dohcVTECeg2's Avatar
Default Re: (mr_nemesis2003)
yea mine looks like a twig awell. i have a stock del sol VTEC one. i think its 13mm not sure
Old Nov 21, 2006 | 11:49 AM
maybe if i change the bushings it'll feel like i have those, lol
a_benito86
Suspension & Brakes
Sep 19, 2016 07:17 AM
amej8
Jun 17, 2008 06:16 AM
SE7EN3S
14
Aug 23, 2004 01:02 PM
jtl
Apr 1, 2004 04:24 PM
