can i pass smog with an aftermarket drive pulley??
Old Nov 20, 2006 | 12:27 AM
EKbeast's Avatar
Default can i pass smog with an aftermarket drive pulley??
i got an aftermarket drive pulley from ebay. do you think i can pass smog with it? or does it even matter. thanks!
Old Nov 20, 2006 | 01:12 AM
fmrprojects's Avatar
Default Re: can i pass smog with an aftermarket drive pulley?? (warren g)
put the stock back on. after market crank pulleys will detrot your oil pump
Old Nov 20, 2006 | 05:58 AM
-Gary-'s Avatar
Default Re: can i pass smog with an aftermarket drive pulley?? (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">put the stock back on. after market crank pulleys will detrot your oil pump</TD></TR></TABLE>
Huh? How?
Old Nov 20, 2006 | 08:04 AM
ASTOCKSI's Avatar
I would also like to know about the oil pump?
Old Nov 20, 2006 | 08:05 AM
blackdelslo's Avatar
Default Re: can i pass smog with an aftermarket drive pulley?? (ASTOCKSI)
He asked if a pulley would effect his emissions retard, not if you think its bad for his car-- no it wont interfere.
edit: a harmonically balanced pulley will not damage your engine.
Old Nov 20, 2006 | 08:07 AM
ASTOCKSI's Avatar
Default Re: can i pass smog with an aftermarket drive pulley?? (blackdelslo)
you must like your post count high
Old Nov 24, 2006 | 10:38 PM
TEST ONLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ASTOCKSI &raquo;</TD></TR><TR><TD CLASS="quote">I would also like to know about the oil pump?</TD></TR></TABLE>
Same here..... also, pulleys will have no ill effect on a healthy engine.
DraginX
May 14, 2012 05:20 PM
phaphon
Mar 27, 2012 07:17 PM
ghostriderinnc
Jun 27, 2010 05:29 AM
061000rr
May 28, 2009 12:25 PM
NateTEG95
May 30, 2003 09:24 PM
