ls-vtec,how high can i rev it?
Old Nov 19, 2006 | 10:05 PM
SpoolnByYou's Avatar
Default ls-vtec,how high can i rev it?
whats up guys,
i have a built lsvtec and was wondering how high can i rev the bottom end to saftly? Its built with arias 12:1 comp. pistons,eagle H-beam rods,stock sleeves. Can the bottom end take high reving like stock vtec blocks?
Old Nov 19, 2006 | 10:36 PM
Fat Chick Magnet's Avatar
if its a balanced block/tuned car... i would say 9000rpm max if your car makes power.
edit: fully built motor
Modified by dc2rtek at 7:49 PM 11/20/2006
Old Nov 19, 2006 | 10:39 PM
nva2nd's Avatar
Default Re: ls-vtec,how high can i rev it? (SpoolnByYou)
Stick it on a dyno, find where max power is...not much point in revving it till 9k if your only making max power at 8200.
Old Nov 20, 2006 | 01:17 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: ls-vtec,how high can i rev it? (nva2nd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nva2nd &raquo;</TD></TR><TR><TD CLASS="quote">Stick it on a dyno, find where max power is...not much point in revving it till 9k if your only making max power at 8200.</TD></TR></TABLE>
best said.
Old Nov 20, 2006 | 01:51 AM
rdblckSV650S's Avatar
Default Re: (dc2rtek)
I would say no more than stock. The only thing you've changed is the top-end's ability to handle revs, the bottom end is still the same rod/stroke ratio.
As has been said, stick it on a dyno and see where it makes power. More than likely it'll look like it just keep making power. I wouldn't recommend reving it past 7500. It's your car. If you've got a good tune then all the better.
Old Nov 20, 2006 | 10:36 AM
Mr Si_Vtec's Avatar
depends on your ecu too
Old Nov 20, 2006 | 10:53 AM
Beau Gotti's Avatar
there is an all motor section on this site.
Old Nov 22, 2006 | 10:12 AM
VTECth1s's Avatar
get ARP head studs and rod bolts, and you can rev the expletive out of it, and still run efficient with a tune of course. But you dont want to rev past where the powerband ends cuz thats just useless and ricer. You should experience rev range up to like 9k.
Old Nov 22, 2006 | 10:41 AM
iH8RICERZ's Avatar
Default Re: (Beau Gotti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beau Gotti &raquo;</TD></TR><TR><TD CLASS="quote">there is an all motor section on this site.</TD></TR></TABLE>
Definitely do some research.... lots of topics regarding lsvtec set ups and all of its pros and cons of doing it. Typically, I tell people not to rev any higher than 8000 if the motor isn't built.
Old Nov 22, 2006 | 11:00 AM
SilverDc2's Avatar
Default Re: (iH8RICERZ)
the bottom end is obviously an LS, so....with that im mind i would have to say 8000-8250 max.
DYNO it and see where YOUR power cuts off, whala! magic.
SpoolnByYou
Nov 20, 2006 08:55 AM
PAndADc2
12
Jun 5, 2005 01:17 PM
VTC_CiViC
Jan 5, 2005 11:09 AM
SimbaDogg
Honda S2000
12
Nov 9, 2004 10:19 PM
Rod.
Apr 18, 2004 04:50 PM
