Ball Joint , Axle , Tire Rod End
My right front wheel when you are driving it u can feel it vibrant and feel it in the steering wheel . When there is weight on the car awhile sitting on the ground when u pull on the tire u can pull it towards you and it clunks a little .. but when u jack it up it does nothing and doesn't move . only when there is a load on it . i am lost i talked to alot of people and was told axle but a axle would make nose . and a wheel bearing but i highly douth its that .. so any in put or if someone has had this problem plz post . Don't feel safe driving the car . thanks guys !
check your bolts on your crossmemeber! i had the same problem as u and i looked everwhere and couldnt find it untill one day i got pissed and just started tightening every bolt i could see and when i tightened the crossemember ones i found that they were loose and this fixed the problem! GL and let us kno if u fix it!
dc5itracer
Oct 11, 2008 09:44 PM
Mendes
Feb 21, 2008 01:46 PM
